Windows 7: Does my system leak sound?
13 May 2010   #11
MattDamonisdumb
Windows 7 Ultimate 64 bit
Quote   Quote: Originally Posted by stormy13 View Post
If onboard from the motherboard manufacturer. If a sound card from the card manufacturer.
This would help as well,
Attachment 72674
If unsure what your specs are grab this,
Speccy - System Information - Free Download
and it should show it.
FYI, i own a Sager NP2096 which shipped with drivers for Vista. I installed Windows seven and Sager told me to get drivers from Compal. Now I see three drivers, one from 2008 which I assume is for Vista. And two others, one for Nvidia VGA Sku and one for Intel VGA Sku. what do you think?
13 May 2010   #12
stormy13
Microsoft MVP
Win 7 Ultimate x64
This it,
Sager NP2096 Specs
if so it has the Realtek ALC268 audio chip on it and the latest Realtek driver,
Latest Realtek HD Audio Driver Version
should fix it right up.
13 May 2010   #13
MattDamonisdumb
This it,
Sager NP2096 Specs
excellent!
13 May 2010   #14
MattDamonisdumb
Final Update:
updating my sound card drivers also appears to have fixed another issue I was having! Can't thank you enough for noticing the driver was missing.
Sound meter software exist for the taskbar?
13 May 2010   #15
stormy13
Microsoft MVP
Win 7 Ultimate x64
You're very welcome.
Only sound from system, No oher software seem to trigger the sound
Hello again A new problem with my PC Win 7 64 pro No sound is heard from software like Excel. Sound issued by the system will be played I did open the sound Mixer and a click on the system icon will play a sound. A click on the 3 others will have no sound play.
Memory Leak: Insufficient System Resources
My practice is to turn off the machine at bedtime and reboot it every morning, so that it gets a fresh start every day. I upgraded to Windows-7 from -XP about a month ago, applied all available updates and thought it the right move until recently. Now after the machine runs several hours, when I...
Performance & Maintenance
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
Any System Monitor Gadgets that DON'T have a memory leak?
I've been on the quest for a good system monitor gadget that doesn't hemorrhage RAM like a hemophiliac running through a thorn bush. All the ones that work good spool up RAM. For example, I really like the CPU Meter III G.5 but running it will eat up all my RAM over enough time. I forgot to...
Customization
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
