Windows 7: Does my system leak sound?
13 May 2010   #1
MattDamonisdumb
Windows 7 Ultimate 64 bit
Please see link for explanation:
Play - ShowMeWhatsWrong.com
Basically, my sound meter keep showing sound but I have none. Is my system simply making sound I can't detect?
13 May 2010   #2
Dwarf
Windows 8.1 Pro RTM x64
I don't think that it is sound as such, rather noise which is caused by the input being left floating. What happens if you turn the MIC volume down when you unplug it (or simply mute the control)?
13 May 2010   #3
MattDamonisdumb
Quote   Quote: Originally Posted by Dwarf View Post
when I mute the mic it goes to zero. Same if i lower the mic voume
13 May 2010   #4
Dwarf
Is that with the MIC plugged in or not? In addition, you should consider turning down (or muting) any unconnected audio channels, particularly those which are configured as inputs.
13 May 2010   #5
MattDamonisdumb
The level fall to zero when I mute the mic with it plugged in and not plugged in.
Where can I find the unconnected audio channels/inputs?
13 May 2010   #6
stormy13
Microsoft MVP
Win 7 Ultimate x64
Try here,
13 May 2010   #7
MattDamonisdumb
Quote   Quote: Originally Posted by stormy13 View Post
thanks man for the help.
attached video to show you and make sure i did it right.
edit: just realized you clicked properties. I did that just now and it's the same anyway.
So basically It seems like it's the Mic-in jack. Does it matter that I get the noise from that jack, as far as it hurting my system or whatever?
13 May 2010   #8
stormy13
Microsoft MVP
Win 7 Ultimate x64
It was a little hard to see in that video, but was still readable. One thing you haven't done is to install the drivers for your sound card. That is why it is showing as "High definition audio device" instead of showing the name of the sound card. It is also why there is only one item showing when you get to the Levels tab.
13 May 2010   #9
MattDamonisdumb
wow good to know, where could i find the drivers?
13 May 2010   #10
stormy13
Microsoft MVP
Win 7 Ultimate x64
If onboard from the motherboard manufacturer. If a sound card from the card manufacturer.
This would help as well,
If unsure what your specs are grab this,
Speccy - System Information - Free Download
and it should show it.
Only sound from system, No oher software seem to trigger the sound
Hello again A new problem with my PC Win 7 64 pro No sound is heard from software like Excel. Sound issued by the system will be played I did open the sound Mixer and a click on the system icon will play a sound. A click on the 3 others will have no sound play.
Memory Leak: Insufficient System Resources
My practice is to turn off the machine at bedtime and reboot it every morning, so that it gets a fresh start every day. I upgraded to Windows-7 from -XP about a month ago, applied all available updates and thought it the right move until recently. Now after the machine runs several hours, when I...
Performance & Maintenance
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
Any System Monitor Gadgets that DON'T have a memory leak?
I've been on the quest for a good system monitor gadget that doesn't hemorrhage RAM like a hemophiliac running through a thorn bush. All the ones that work good spool up RAM. For example, I really like the CPU Meter III G.5 but running it will eat up all my RAM over enough time. I forgot to...
Customization
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
