Sound Driver Help !
  1. Posts : 7
    Sound Driver Help !
    I've recently upgraded to Windows 7 Professional. I just noticed that my sounds were broken. I've been trying to fix this, but still no solution.
    I use an Intel Motherboard and SoundMAX for my Sound drive. I noticed that my SoundMAX was just version 5.+, so I checked Intel's site and downloaded the version 6.+ but I get an error while installing.
    http://i41.tinypic.com/qpnz7o.png
  2. Posts : 11,840
    64-bit Windows 8.1 Pro
    We could provide more assistance if you filled out your system specs..
  3. Posts : 7
    OS: Windows 7 Professional
    OS Version: 6.1.7600
    CPU: IntelR PentiumR 4CPU 2.00GHZ
    Motherboard Model: D845EBG2
    Manufacturer: Intel Corporation
    RAM: 2GB
    Video Adapter Name: Standard VGA Graphics Adapter
  4. Posts : 11,840
    Here is the download page for your motherboards' drivers .. it shows your audio codec as AC97 and Windows XP is the latest supported OS... If you decide to install this, you must install it in Compatibilty mode... Hope this helps..
    Compatibility Mode
  5. Posts : 7
    Oh, I see.
    I tried installing through Windows XP SP2
    It said that HDA Audio bus driver is required and not found
