You mean after I quit CPU-Z? Yes, they do although it seems like there are not as many after quitting. But the audio dropouts are still there, even if they don't get "represented" by red bars. Only a restart or sleep->wake fixes them.
edit: also, there's a red bar almost every time I open a program, but it doesn't seem to affect audio the same way as CPU-Z does.
MB is Asrock ALiveNF6G-VSTA, the CPU is an Athlon 64 4000+ X2 (65nm). 2GB of 667 DDR2 RAM. GPU is a 5450 now, but I tried with the onboard as well and it's the same. (Onboard is disabled now.) I also have a USB Wlan adapter, which I tried unplugging, but it didn't help (also, when there's some internet traffic the latency goes up a bit, but it doesn't affect the audio). One PATA HDD, one SATA DVD.
BIOS is updated to the latest version. (And it was the same with an older version.)
