Realtek AC 92 W732 no sound from green jack.
  1. Posts : 23
    Windows 7 32-bit
    Hey guys...I am wondering if you could help me out. I have a similar problem with the green output not working. I am using a "normal" realtek onboard sound. Iīve tried meddling with some settings without any luck until I saw this thread...and itīs for Realtek HD, but maybe you can help me out. I managed to navigate in regedit but am unable to figure it out what to change, or wether itīs possible or not.
    Uploaded with ImageShack.us
    Itīs a MSI RS482M2-IL/ L
    The version from Realtek homesit and mine are the same.
  2. Posts : 846
    Windows 10 Pro
    Not sure why it doesn't work but I must ask a few questions.
    Has it ever worked under Win7?
    Do you have other output jacks that you can test with?
    Are you tried any other speaker to eliminate the ones that don't work?
    Did this stop working after you installed Win7?
    Hope to hear back from you soon.
  3. Posts : 23
    Windows 7 32-bit
    Well, the blu one works, if I set it to surround...I get sound from there...but only front left and right. I havenīt really tested the microphone input...but I tried putting the microphone into that one and I got no sound.
    I am pretty sure that it worked before in Windows XP, been a while though...but itīs apparently a known problem.
    I figured if it was possible to change the G-B and B-G, like with Realtek HD.
Đ Designer Media Ltd
