Windows 7: Need help installing my sound card
26 May 2010   #11
mienboix2
windows 7 Home Premium 64-bit(6.1, Build 7600)
Quote   Quote: Originally Posted by Aphelion View Post
Quote   Quote: Originally Posted by mienboix2 View Post
Its a PCI card. My motherboard only has 1 slot to try it =/. How can i check to see what kind of soundcards are compatible with my motherboard?
When you first installed it, did Win-7 give any indication at all that it was recognized?
Ap
p.s. do you have any other PCI slots used by other hardware?
Well after i put it into my motherboard, i turned on and then windows said it was trying to detect the driver, so it led me to the download link to download it. After downloading, i tried to install but got that error; nope. i do not have any other PCI slots used by other hardware. This is the only thing i ever putted inside my computer since i bought it.
p.s.
When i check device manager, under Other Devices, it lists Multimedia Audio Controller which has the yellow triangle "!" sign. When i check its properties, it says "the drivers for this device are not installed." Not sure if this has something to do w/ it or not. and it leads to the same download link as when i tried to install the sound card. So i guess it does has to do something with it.
26 May 2010   #12
kucing13
you need to identify what brand/type of sound card you have,and refer to the brand website to download the drivers
26 May 2010   #13
Aphelion
Windows 7 Home Premium
p.s.
Ok... well, I guess it's just a matter of finding the right driver.
This is your card, correct?
Creative Worldwide Support
Ap
27 May 2010   #14
mienboix2
@Aphelion: yeah. Thanks for your help. I finally found the issue. Because windows detected it as X-fi Xtreme Audio, i believed it and decided to dl those drivers. After i decided that these didnt work, i thought to myself that this must not be the right sound card. So i decided to recheck how my sound card looked like and now it matched the x-fi xtremegamer. I dl the most recent drive and now it works! Thanks for all your help once again!
27 May 2010   #15
Aphelion
Hey, good work!
Rep yourself!
Ap
Wonder HDTV tuner cant start after installing Dynex Envy 24 sound card
Without the Dynex PCI sound card, HDTV wonder is good. Put in the Dynex card, install drivers (one exists at windows update), tuner code 10 device cant start. I suppose there is nothing to do about it? I tried uninstalling the tuner. I moved cards around in slots. Why cant the tuner...
Hardware & Devices
BSOD while installing Sound card
Hi, I would like someone to help me with this BSOD Got a BSOD while installing Creative Audigy 24Bit SB live Here's the minidump file attached.. Thxxxxxxxxxxxxxxx
BSOD Help and Support
Sound Card Driver Has a Dificult Time Installing
I have a HT Omega Claro sound card that I've been having problems with. One issue that I have is after I uninstall the driver and try to reinstall it. It takes several attempts to install successfully. Does this mean that the sound card is fualty? I'm not sure exactly how a driver works but...
No sound after installing new graphics card
so today after installing my new graphics card Radeon hd 4850 1gb and new 600 watt power supply i started my computer up just to see if it runs properly not plugging in everything because i was just being lazy anyways i updated the graphics card by downloading the updates from this site ATI...
No Sound from HDMI Port after installing ATI Radeon 5750 graphics card
After I installed my new graphics card physically, I switched my display to a Sony LCD TV and plugged it into the HDMI port on the graphics card. After that, I installed all included device drivers and have since updated my Catalyst drivers. Still, I don't seem to have any sound from the TV, though...
Twitter Facebook
