does not detect sound card
  1. Posts : 4
    windows 7 dual-booted with xp pro sp3
    i got the windows 7 RC 32bit yesterday and it doesnt seem to detect my sound card, i have tried installing the driver but have had no luck with that
    my sound card is Hercules Gamesurround Fortissimo III 7.1
    any ideas? i have googled for a solution but havent found anything
  2. Posts : 1,524
    Hello thewink,
    This is always going to be a problem with older hardware as the manufacturers just don't see the point of releasing new drivers You might be better off getting a new card.
    Try this link; http://www.xpvistasite.com/gamesurro...i_7.1_3732.htm
    Pooch
  3. Posts : 4
    thanks for the reply pooch, never thought that would be a problem since i have never had a problem with that sound hard
    im gonna try to talk my parents into buying me a newer sound card if the driver from xpvistasite wont work
  4. Posts : 1
    If you haven't already solved this problem, I had a similar thing with my Gamesurround Fortissimo II card. I've just got it working by first installing the vista/xp drivers from the hercules website. Then I went in to device manager (right click computer->manage) and found the sound card (it may have been called unknown device), right clicked on that and chose update drivers and then pointed the wizard to the folder :
    C:\Program Files\Hercules\Audio\Crystal Sound cards
    It successfully installed the drivers and now I have sound.
  5. Posts : 4
    thankyouthankyouthankyou numb
    i'll try that right away
  6. Posts : 4
    ok i think the drivers installed properly now, thanks ^^
  7. Posts : 287
    7600x64 RTM
    Buy a HT claro plus
  8. Posts : 2
    Windows 7 Enterprise x64
    THANK YOU!
