sound card issue
  1. Posts : 6
    sound card issue
    can anyone tell me ?why speaker is not working ?meanwhile microphone is working .
    i am using hp laptop.kindly let me know the idea.any help would be highly appreciated.
  2. Posts : 1,747
    window's 7
    maybe filling your system specs and telling us you laptop model can help us to help you. I believe this a problem with sound driver. :)
  3. Posts : 6
    Kindly find the attachment for sound card hardware id .and let me know the idea.
    Attached Thumbnails Attached Thumbnails sound card issue-hardwareidforspeaker.jpg
  4. Posts : 4,772
    Hello !! Welcome to SF !!
    What laptop are you using ?? What is the model of it ??
    Edit: I found two Audio Drivers that might work for you
    Conexant HD-Audio SmartAudio 221 Driver Compaq Presario V3713TU Notebook PC - HP Customer Care (Singapore - English)
    Conexant Audio Driver (32-bit) Compaq Presario C300EA Notebook PC - HP technical support (United Kingdom - English)
    Captain
  5. Posts : 1,747
    window's 7
    can you provide us with your laptop model ?:)
  6. Posts : 6
    hp pavilion dv6000.
    our sound card hardware id is :
    HDAUDIO\FUNC_01&VEN_14F1&DEV_5045&SUBSYS_103C30BB&REV_1001
  7. Posts : 1,747
    window's 7
    try downloading the sound driver from HERE. It says vista,but it maybe works with seven too
    edit: install the driver in compatibility mode. right click the installer>properties>compatibility mode>vista.
  8. Posts : 1,747
    window's 7
    for your toshiba. you can download your driver from here and here
    In any case if the drivers for windows seven is not available. you can try installing it in vista compatibility :)
  9. Posts : 6
    i have downloded and tried to install but fail.This is also not working.i am using u300 model of toshiba laptop.and microprocessor is x86.kindly let me know the idea.
