Please help me set up SPDIF
  1. Posts : 525
    Window 7 Ultimate 32bit
    I bought a HDMI screen with built in speakers but the sound doesn't work and I was told I must plug in the wire on my graphics card and then plug that into spdif on my mother board I did it but there is still no sound what must I still do. He said I must enable it in the BIOS but where is that?
  2. Posts : 6,879
    Win 7 Ultimate x64
    Are you using the onboard sound or a sound card? Do you have it set to use SPDIF as the default audio device? How are you connecting to the monitor (DVI-HDMI cable, DVI-HDI adapter with a HDMI cable)?
    What you have listed in your specs doesn't make much sense. Would also help if you listed the model number of the motherboard.
  3. Posts : 525
    okay I do not use a sound card I use onboard and I have the monitor connected with a HDMI cable, and the motherboard is GA-G31M-ES2L/GA-G31M-ES2C. and I have set the spdif as default adio device and I can see the bars moving up and down as the sound goes but the sound doesn't come out the speakers, so what could the problem then be?
  4. Posts : 6,879
    Win 7 Ultimate x64
    You may have the connector on the motherboard reversed, try flipping it around (pin 1-2 to pin 2-1).
    Also is it set to SPDIF passthrough in the Realtek control panel?
  5. Posts : 525
    I have done it as the manual said pin 1 is red wire and pin 3 is GND I tried it that way and I tried it pin 1-2, but still no sound
