No Sound - Realtek HD Manager Misreading
  1. Posts : 3
    Windows 7 Ultimate
    My sound has always been working just fine. I usually had it plugged in the front panel of my Ultra eTorque case and I had the Realtek HD audio driver installed. But earlier today, I moved my computer to the living room to connect it to the TV through the DVI port and when I had my computer displayed on the plasma TV through HDMI, my sound just disappeared. All I did was unplug the cables to move it to the living room and connect it back and then it just stopped working.
    What's worse is how the Audio Manager is just acting... odd. For example, right now I have no speakers or anything connected to any audio jacks or mic jacks or anything of the sort. And yet, when I pull up the manager, it says there's a mic already plugged into the front panel. I've never even owned a mic so it's a bit odd to me why this would happen. And I have iTunes playing in the background and it shows the audio is playing as Realtek Digital Output(RCA), but nothing's coming out, as you can see in the first picture.
    Now to top that off, I go ahead and plug in the speakers into the front panel, and a few things happen. First, the "mic" is unplugged and I get a warning in the bottom corner says an audio device has been unplugged, as seen in the second screenshot. Then, I get an odd pulsating high pitch from the speakers, it's not very noticeable but it's there and it's definitely not normal. I've already tried plugging it into the rear panel but no success.
    I've already searched through the forums and haven't found anything to help that I haven't already tried. I'm not sure if this is relevant, but if someone can assure me that this could be my solution, I'd be heavily grateful.
    Realtek HD Changing Jack output reassignments ( FIX )
    I'm just hoping to get a bit of help here, and I'll be more than happy to give more information or try a few things you guys have to suggest. Thanks in advance!
    Attached Thumbnails Attached Thumbnails No Sound - Realtek HD Manager Misreading-untitled.png   No Sound - Realtek HD Manager Misreading-untitled2.png
    Last edited by PatentPendingX; 13 Jun 2010 at 16:13. Reason: Forgot to add the link to the other post
  2. Posts : 3
    Windows 7 Ultimate
    Well, I sorta fixed it. I plugged in the speakers to the orange jack and when it asked what kind of output it was, I just chose front speaker out. But can anyone help with the odd mic problem and maybe configuring this right?
