Gateway NV53 minor problem
  1. Posts : 2
    There are touch sensitive buttons just in front of my keyboard, it previously showed on the screen that i had hit increase/decrease or mute. Does anyone know how to reactivate them?
  2. Posts : 52
    Windows 7 Ultimate RTM
    Did you do a "clean" install of a new operating system than what had been shipped with your Notebook? If so, you will have to go to Gateway to get the drivers you need. You can check on this webpage at Gateway for available drivers: Gateway Support Drivers & Downloads
    Or, click on the "My Downloads" tab on that page and then enter the serial number of your Notebook to find more appropriate downloads.
    Good luck.
    Jim
  3. Posts : 2
    Fixed!
    Thanks! I just had to update my launch manager and it fixed the problem.
