Windows 7: 5.1 sound system problems.
18 Jun 2010   #1
eduards53
Windows7
I have Logitech x-530 and yesterday i changed Windows Xp to Windows7 and now my speakers is not working only front 2 and sobwoofer but rear and center speakers is not working what to do plz help. I have 2.1 soundcard but with windows xp i used 5.1 system true Realtek HD audio manager. But now is not working
18 Jun 2010   #2
severedsolo
Windows 7 Ultimate X64 SP1
Welcome First things first, have you tried installing the latest Realtek Drivers? Latest Realtek HD Audio Driver Version
18 Jun 2010   #3
eduards53
Windows7
yes
18 Jun 2010   #4
eduards53
Windows7
hey where i can get this version i laiked it better
18 Jun 2010   #5
eduards53
Windows7
and problem thets in all tests all speakers is working but in programs or web not
18 Jun 2010   #6
severedsolo
Hmm.... I will hold my hands up and say I'm not an expert here.
But that sounds like everything is working, possibly the programs you are using aren't built for surround sound? I would imagine that they will only use all the speakers if the program tells them to...
18 Jun 2010   #7
RST101
Windows 7 Ultimate x64.
Have you tried speaker fill in realtek manager?
18 Jun 2010   #8
eduards53
Windows7
RST101 TNX WORK
18 Jun 2010   #9
RST101
Glad to be able to assist
18 Jun 2010   #10
Fantail
7 x64 | 7 x64
Hang on a sec, fill works but its not 5.1 sound.
This might not work with your board but you'll need to use different jacks on the board panel. For my board I used green, orange and the black jacks and then I get 5.1 on the x-530's. Once you go into your audio manager panel test your 5.1, center, sub, side pair, for full range front left and right, surround speakers are checked.
PC sound problems. No system sounds, no audio.
Dell Studio XPS 8100 Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz (4 CPUs), ~2.7GHz 6 GIGs of RAM Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 I here as a last resort before formatting my hard drive. A couple of weeks ago the sound on my PC up and died, for no apparent reason....
Only sound from system, No oher software seem to trigger the sound
Hello again A new problem with my PC Win 7 64 pro No sound is heard from software like Excel. Sound issued by the system will be played I did open the sound Mixer and a click on the system icon will play a sound. A click on the 3 others will have no sound play.
Audiophile 2.1 sound system for Xonar D2X sound card.
I have given up on getting a good 5.1 or 7.1 sound system for my pc since it requires a receiver and all. What I am looking for right now is a 2.1 sound system that can be directly plugged in to my Asus Xonar D2X sound card. The system should have a really decent subwoofer with tight and deep...
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
sound problems with Realtek ALC 882 sound card
I have a HP Media Center PC. the Model number is a1412n I am dual booting xp and windows 7, and in windows 7 I am not getting any sound. When I went to check it out, I realized that the computer was only recognizing the front audio jack. So i plug my speakers into the front jack but it still says...
