Windows 7: Intermittent sound problems x64
24 Jun 2010   #1
aalaptop
windows 7 x64
hi all,
I built a pc for someone and they are experiencing sound problems, the problem I have it that it doesnt act up on me. So here are the symptoms. While listening to something the sound will start breaking up and then completely stop. After reboot it works fine. I just want a proper solution (not a dodgy uncle solution) to get this monkey off my back. What we are going to try is:
update the sound and directX drivers (a given)
should that not work I will try a pci or usb sound card
I was just wondering given these symptoms and this config, does anyone have a silver bullet solution? the setup is as follows
windows 7 x64
JW-A780LM-D2 motherboard
4gb of ram and an AMD x2
Realtek ALC662 intergraded sound card
thanks!
24 Jun 2010   #2
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by aalaptop View Post
hi all,
windows 7 x64
thanks!
I have the same Realtek audio on my Gigabyte mainboard.
Latest Realtek audio driver is 2.49.
Here's a couple you may have missed.
Definitely update the motherboard BIOS to the latest.
Make sure the Network Adapter is updated to the latest drivers, if not from Microsoft, the manufacturer's website. (I'm using the latest realtek NW drivers from Microsoft).
If the machine has wireless... same deal, check on updated the drivers.
In the BIOS, disable all legacy ports not being used, (ie: serial & parallel)
A great tool is the DPC latency checker, simple install no "extra" files, no writing to the registry. Will help you pinpoint if it's a driver issue.
DPC Latency Checker
Ap
Intermittent distorted audio with Nvidia HD Sound.
Hi there, recently I've started noticing that when I'm using the Nvidia HD audio most times when I either start up a program or switch tabs on Chrome my audio distorts and gets slow, this happens across all audio platforms (iTunes, YouTube etc). It's driving me nuts and I'd like to try and find...
Sound Intermittent
Hi all I have a ASUS DGX 5.1 sound card. When I play music or play any game I get the same. The music or games I play sounds if they are underwater in a echoey tunnel wind tunnel. I have tried 2 different sound cards and headphones but get the same. I have updated all the drivers on my system....
Intermittent sound on new installaton with new mobo
Hi all, Last weekend I upgrade my computer with a new mobo as well as a new case. This case front panel jacks for headphones and a microphone, which is the main reason why I bought it. Case : CoolerMaster 690 USB 3.0 edition MOBO : Asus M5A97 R2.0 The case and mobo offered two choice for...
intermittent bsod problems
Hello everyone for the past month i have been experiencing random bsods. When it first started it would blue screen only a handfull of times during the first 2 weeks. I would be able to use the pc for hours playing games or surfing the web with it only bluescreening once every 2-3 days. The next...
BSOD Help and Support
intermittent sound output :s
Hi all, so I've been trying to figure out what's going on with this acer 5520 amd 2ghz, 3gb laptop. Basically this is what I've checked and done: drivers updated, bios updated/re installed re seated all internal components I.e: cd drive, ram, hdd . Fresh install of vista, win 7 and finally xp...
