Windows 7: Problems with Supreme FX II audio drivers
06 Jul 2010   #1
altek
MS Windows 7 Professional 64-bit SP1
Hey everyone,
Just registered here because I am at my wit's end with this problem. OK.
Using a Supreme FX II riser card for an ASUS P5E motherboard. Windows 7 x64
Had XP, all drivers worked, was using SoundMAX control center. No problems with my microphone, speakers, headphones, etc. Then I did a fresh install of Windows 7. Sound worked. Everything was fine until I tried getting my microphone to work. Seems like A LOT of people are having similar problems with driver issues, hardware, etc. A lot of people can't get their mics to work on Windows 7, etc. My speakers work fine, I am using my speakers as "High Definition Audio Device" default, which I am guessing is the default for a Win 7 install. I have tried both HD-Audio and AC'97 on the sound card. It's definitely not a hardware issue. The sound card works.
Basically, my motherboard CD won't run on Windows 7, so I can't try installing the drivers off of it. I went to the ASUS website and tried downloading the newest audio drivers for the P5E. I install it and I get errors. The drivers won't load after a restart. I just get a red X in my sound tray and no audio at all. I uninstall it and get the default Windows 7 drivers back and my audio works. But no microphone. Just a Line-In in recording devices. I have scoured Google and other forums, seeing a lot of people have similar issues, but nothing that I can really work with. I have tried other versions of drivers recommended, same problem. I am pretty sure it's a driver issue because I know I didn't install any manually when I installed Windows.
Anyone have any experience with the Supreme FX II and Windows 7? Any advice or suggestions are welcome. I don't know what else to do. I hear conflicting things from other forums and people. Really looking for help here since a lot of other people are using Vista or XP. I don't see a lot of Windows 7 stuff and that is what I am running here.
06 Jul 2010   #2
MK2
Have a look at this thread:New Soundmax driver!
MK2
06 Jul 2010   #3
altek
Quote   Quote: Originally Posted by MK2 View Post
MK2
I'll check it out, but I have tried a couple driver versions, including the ones right off the ASUS site that are supposed to work in Win 7, but no dice. I install and I get the red X and "Drivers could not be loaded" upon restart. No audio devices present at all. I'll try this one out though and see how it works. Thanks.
Edit: Installed it, same thing as the other ones. Red X in sound tray, 'unable to load drivers' after restart. Went into device manager, SoundMAX Integrated Audio was there but with a yellow exclamation. I tried to update the drivers through there and it just installed the Win 7 defaults. No audio devices present in playback or recording when I installed, until it reverted back. Sigh.
07 Jul 2010   #4
MK2
To be sure did you try this driver:
SoundMAX Audio Driver v6.10.x.6585 released October 21, 2009 WHQL
Be sure before you install to remove any leftovers from the old/other soundmax drivers.
Here are all the drivers from Asus:
ftp://ftp.asus.com.tw/pub/ASUS/misc/audio/
07 Jul 2010   #5
altek
http://dlcdnet.asus.com/pub/ASUS/mis...pVistaWin7.zip
Yes. I've tried both. They install, but then have problems loading. "Driver unable to load" upon start up. No audio output device at all. Uninstall or I update drivers from device manager and it reverts back to Win 7 default sound drivers.
07 Jul 2010   #6
MK2
To help you better could you fill out your systems specs, here's how to: https://www.sevenforums.com/general-d...ease-read.html
Also could you post a screen shot of the recording section in audio?
Something you also could try is to use the Windows 7 disk to perform a "repair" (select upgrade install)
Another user on this forum with sound problems solved it by doing this.
08 Jul 2010   #7
altek
OK. I set my system specs up. Also I took some screenshots of my current recording and playback devices in my audio.
I don't understand how using Win7 to repair it would work. I thought it was a separate driver issue. I'm using the Windows 7 default drivers for audio. I just want to get my mic working, that's all really.
I'd like to get this resolved somehow with Windows or my drivers to be able to use a mic as a recording device, but would a USB microphone work since it's not plugging directly into any analog mic jacks or anything? Or do I still need a microphone as a device in my recording devices?
08 Jul 2010   #8
MK2
Sorry for the late reply but we had a power out here in Amsterdam.
I thought it was worth a try to do a repair.
Looks like it but to be sure in your bios it's set to hd-audio?
Also did you already had a look at this thread: ASUSTeK Computer Inc.-Forum- Windows 7
second page, last posts.
I never used a usb mic but in theory it should work, it uses a separate port and drivers.
16 Jul 2010   #9
MK2
Was wondering, did you find a solution to your problem?
MK2
Laptop audio problems possibly involving built in VIA High Def Audio
Hello I am new to this forum. I have searched for related problems here but did not find anything relevant, my apologies if this is a duplicate. What follows is a copy of a message sent to VIA (in Taiwan apparently): I seem to be having some issues with your VIA High Definition Audo drivers...
Drivers
Supreme X-Fi Jacks
Hello, I've a Supreme X-Fi Sound device, that came with my Asus Crosshair III Forumla motherboard, I need to change the Jack assignments for this device :mad:, any ideas?:) Thanks in advance, Ahmed.
Onboard audio not working and audio drivers won't install
Hello everyone, I'm having a problem using my motherboardís onboard HD audio instead of my video cardís audio, so without further ado here is the situation; I have an Asus maximus iii gene motherboard which has a SupremeFX X-Fi built-in sound card (this is a very nice card provided you can...
ASUS Supreme FX II
Hi guys. I got Asus Supreme FX II sound card to install to Gigabyte-890GPA-UD3H motherboard. Question No.1: Would this two devices work together or Asus sound card only for Asus motherboards? Question No.2: Where to find drivers for sound card? Thanks (d)
supreme fx 11 drivers
i cant seem to find any drivers for my sound card(one that came supplied with the mobo), its a supreme fxII ,i've tried drivers for XP and vista in compatibility mode but all i get is the error "does not support this operating system:WNT_6.1P_64_MCE" i have a ASUS p5n32-e sli plus motherboard...
