Windows 7: Help with headset, Can hear sound but not record
15 May 2009   #11
Dwarf
Windows 8.1 Pro RTM x64
Hi nyliferocks,
What is the make and model number of the headset?
15 May 2009   #12
nyliferocks
Hi, Its a Jenson JTH950 Headset that came with a 2.5mm plug but I purchased a 3.5mm adapter so I can plug it into the computer
15 May 2009   #13
Dwarf
Sorry, but this is not suitable for connection to a computer. This model is designed for use with a mobile phone.
Have a look here for suitable devices [ame=http://www.amazon.com/s/ref=nb_ss_gw_1_7?url=search-alias%3Daps&field-keywords=headset+with+microphone+for+computer&sprefix=headset]Amazon.com: headset with microphone for computer[/ame]
15 May 2009   #14
nyliferocks
Even if I have the 3.5mm adapter on? So I can only use it as an ear piece maybe which can eliminate the echo
15 May 2009   #15
Richard B
Win 7
I've given up. My intel board has embedded audio so I'm going to remove my (2 month old) Creative and see if I can get the Mic to be picked up with Intel's version. I use Skype to stay in touch with family and friends in the UK so not having a Mic isn't an option. If this doesn't work I'll restore my Acronis backup with XP. I don't want to but no mic, no good.
15 May 2009   #16
Richard B
Win 7
Success! I took out the creative FX and the system instantly recognised my microphone. OK, it's not got all the features I wanted with the FX but at least I can now use Skype! So what have we learned: That Win 7 doesn't know how to deal with more than one iteration of a sound device. Maybe it's the same for people using built-in video cards too?
Hope this has been useful to someone.
18 May 2009   #17
rajinisback09
Windows 7 Ultmate 32 bit 6.1.7600 Build 7600
Hi Richard B,
Before installing the Creative card did you disable the embedded audio in the bios? If not then no wonder Windows 7 was defaulting to the embedded audio device. :)
Raj
18 May 2009   #18
Richard B
Win 7
For someone who pops into this dialogue with less-than-useful tips your comment makes it sound as though this was obvious...
Given that was not necessary under XP how did you arrive at that conclusion?
Please don't troll Raj... either contribute or don't.
19 May 2009   #19
nyliferocks
What about some kind of splitter that lets me plug in my headset to the headphone jack and the mic jack? Then could I make my headset work?
How record internally the sound I hear from the speakers?
I wonder what it would take to record (using e.g. Audacity) the sound leaving my sound card? Lets say I listen to a newscast and want to keep the entire thing or snippets of it for reference - what would I need to do that? Windows (7) reports under the Sound/Recording tab (right-click speaker...
Help, I can't hear sound from my headset nor my speakers.
Hello fellow community, I've been having trouble since about 2 days back, my headset and my speakers worked just fine till i shut the computer down for the night. then the following morning there was just no sound, I kinda tried everything these days but nothing works...Anyway, I got a steelseries...
Headset Fatal1ty doesn't record sound
Hello everyone, I'm having a bit of a problem. I can hear myself speak in to the mic, so the mic 'reads' my words and my speakers play them back at me. But for some odd reason I can't get it to record my words with any kind of program. Please, I need help!
Audacity will not record what-u-hear SB X-Fi
Hi All; I know that this is partially addressed in other threads, but I've not found a solution to my specific problem. I have a Dell T3400 with Creative SB X-Fi Model SB0770. Everything works fine in XP on the same dual-boot box. It is a new Vista-ready system and I was able to use the...
No ( Record What U Hear)
I am running the Sound Blaster Audigy and it worked with the drivers that came with Win 7. It did not have Record What U Hear. I tried to install the Drivers that came with the card and it took out the Win 7 drivers and I had no sound at all. I went to Creative Web Site and downloaded the Beta...
