Help with headset, Can hear sound but not record
  1. Posts : 26
    I have my headset plugged into the front green port which has a picture of headphones. Im not sure if the mic should be unmuted or a line in. Right now I can hear sound but I can not record. Does anyone know what could be causing this or what settings I should check?
    I have sound blaster software which really only has 2 options to work with headsets and both are checked in the console. Automatically enable headphone settings and automatically mute speakers.
  2. Posts : 82
    Windows 7 Ultmate 32 bit 6.1.7600 Build 7600
    Hi nyliferocks,
    Speakers should go into the green port yes. The Mic usually plugs into the red/pink port.
    Raj
  3. Posts : 26
    What about for a headset that can hear sound and record? I have my headset plugged into the front of the computer that shows a picture of a headphones
  4. Posts : 82
    Hi nyliferocks,
    Does your headset come with a mic too? If so does it have 2 jacks on it. Maybe 1 green and 1 red? Or is it USB?
    Raj
  5. Posts : 26
    The headset came with a 2.5mm jack and I purchased an adapter to make it a 3.5mm so it can plug into the computer. The headset has an attached mic and 1 ear piece. What would be the best jack to place it in? The front headphone jack is the closest so I was hoping I could use this to gain some flexability with the length of the cord.
  6. Posts : 7
    Win 7
    This seems to be a common issue and is clearly a bug within Windows 7. I have a Creative X-Fi card which worked perfectly under XP.
    It works perfectly under 7 too, except it will not pick up the microphone, saying it is not plugged in.
    7 is a brilliant OS but given the volume of issues posted on various sites about recording devices not working, it's certainly something MS needs to look at.
    Any advice would be great:
    Intel M/B,
    X-Fi soundcard
    ATI Radeon 4800
    4GB RAM
    Dual core Pentium...
    it's a very clean system with no mods.
    Like I said, any ideas, let me know
    cheers
  7. Posts : 26
    I did have this problem with XP and I ended upgrading to 7 before I found a way to make this work. So I believe its just my settings.
  8. Posts : 7
    Win 7
    errrr... OK.
  9. Posts : 82
    Hi nyliferocks,
    Can you enlighten us on how you fixed the issue in this thread? :)
    Raj
  10. Posts : 26
    I never fixed it. I meant to say, I upgraded to Windows 7 before I could find a way for it to work. So its still not working. Sorry for the typo. If anyone can help me and poster Richard B with our settings please let us know. :)
