Windows 7: No sound, "Not plugged in" when it clearly is
07 Jul 2010   #1
Hunsrus
Evening Gentlemen,
I've installed Windows 7 Ultimate x64 for the first time today. Everything seems to be in order except for the sound. I haven't been able to produce any whatsoever.
When I go to control panel > Sound, this is what I get:
I have an onboard soundcard on an Asus M4A79XTD motherboard. Windows sees this, but keeps telling me my shit is not plugged in while it clearly is.
I've been ****ing around all day trying to solve this, but no dice. I've tried drivers and all that but to no avail, and I'm running out of ideas here.
I do not have S/PDIF and the USB device you see at the bottom is my USB mic which is seen as an I/O device but is obviously really only an "I" device.
Can anyone help an increasingly desperate man out? Any help would be greatly appreciated.
Thanks!
Hunsrus
07 Jul 2010   #2
theog
ME/XP/Vista/Win7
Have pluged into the jack.
07 Jul 2010   #3
Hunsrus
Hahaha, yes I have plugged in the jack.
07 Jul 2010   #4
Hunsrus
Gentlemen,
I fixed it, turned out all I had to do was plug in my headphones to the rear jack. Sorry for bothering you :P.
Hunsrus
07 Jul 2010   #5
theog
ME/XP/Vista/Win7
You are welcome, we are here 24/7 to help.
07 Jul 2010   #6
stormy13
Microsoft MVP
Win 7 Ultimate x64
One thing you might want to do is to install the drivers for the onboard sound, which from that screen shot are not installed. At the moment it is running on whatever default driver Windows installed for it, as shown by it being listed as just a "high definition audio device". Once the driver is installed it will then be shown by the device's actual name.
You motherboard has the Via VT1708S audio on it and you can get the latest driver for it from Asus,
ASUSTeK Computer Inc.
or there is a new beta that came out recently for it that can be found on the Via forums,
New HD audio driver released! - VIA Forums
Laptop shuts down at 96% battery and "Plugged in, not charging" issue
Hi all, Laptop is a 5 years old HP Pavilion DM4-2153ca. Issue started a few months ago when laptop was shutting down at 63% battery, and when I plugged it it would charge until 9x% and then say "plugged in, not charging". In the meantime I upgraded to Windows 10 and the issue wasn't solved....
General Discussion
Nvidia HDMI "not plugged in" (greyed out), video, but no audio
Hi all, Here's my setup: Nvidia video card>HDMI out to Sony Home Theater System>HDMI out to Samsung HDTV. I use this to get 5.1 LPCM surround sound for video games. It worked fine until I did a firmware update on the Sony unit. Now, the HDMI audio is greyed out in Windows 7 audio playback...
Can no longer find "USB Audio Codec" when device plugged in
When I right click on the tray speaker icon and select the sound window, I can no longer find the "USB Audio Codec" selection when the device is correctly plugged in. The USB device still works because I can test it on another computer. It is present in the devices and printers window. Software...
Laptop speakers emit a "pop" sound after "Starting Windows"
For a couple weeks now, My laptop has been making a "pop" sound everytime on start up after the windows logo comes together it makes a faint pop sound then continues to the login screen. Everytime I muted or unmuted the speakers it would make the sound too. I changed my driver the the Windows...
ATI HD Sound "not plugged in"
Hello. I just installed Windows 7 on my computer and I'm trying to figure out what's going on. I've been searching for hours and can't find an answer. All I know about my motherboard is that the company is ASUS and it has built in sound. It also has built in video, but I upgraded it to an...
