Windows 7: A8N32 SLI Deluxe Sound Problems
11 Jul 2010   #1
sortax
Hello, I have some problems fixing my sound.
I use the mother board integrated sound card ( Realtek AC'97 ALC850 ) And I use these speakers: Logitech X-540 5.1 Surround. When I set up the configuration and test I can hear all speakers, I select 5.1 and everything works fine. But when I listen music and or videos or anything that need sound, even youtube, only my Front R/L + SubRoofer are working. In the Asus thing utility I selected 6CH surround and even tried 8CH but in vain. I tried 7.1 and its the same. Since the speakers are working when I test with windows audio configuration, what is the problem? I need help please! Thanks!
11 Jul 2010   #2
bobkn
Windows 7 Pro X64 SP1
At a guess, you're getting stereo sound from a stereo source.
Some sound card software can synthesize multichannel audio from stereo. Otherwise, stereo normally plays out the front speakers.
Try some 5.1 source material (like a DVD, if you can).
21 Jul 2010   #3
sortax
Ok I fixed it. I had to check the 5.1 in windows configuration and 6CH in the sound effect thing by realtek at same the 2 options opened. It resolved my problem.
Asus A8N32-SLI Deluxe Drivers
I installed Windows 7 on a system running a A8N32-SLI Deluxe. Two drivers didn't install. And they won't either. They didn't work in Vista too. The MIDI and the Game Port has to be disabled in the bios. Thought I would post this just in case anyone else is using this board.
Drivers
HDAV1.3 (deluxe) windows 7 sound problems
hey everyone, as title states im having probs with it in 7, when using 5.1 and i scroll down on anything, it goes crackly, then cuts out, then to get it working again i either keep scrolling and it cuts back in or just switch the sample rate in the xonar sound panel. i have treid playing with...
sound problems (humm) OR whistling noise wile useing the asus drivers does anyone know how to fix this? thanks anyone Asus A8N32-SLI Deluxe windows 7 x64
A8N32-SLI Deluxe Driver issues?
I've been getting a lot of internet hangs that require multiple retrys to get the website and programs 'not responding' for 20-30 seconds, though the latter has lessened since install. It's been suggested that I update the chipset drivers and see if it helps. The problem is I can't seem to find...
Drivers
A8N32-SLI Deluxe (ALC850) AC97 - Popping/clicking sound
I own a A8N32-SLI Deluxe motherboard and in Windows 7 (x86), a popping/clicking noise can be heard before and after any sound is played, be it the Windows Explorer sounds or a mp3 file or video. The best I can describe it is, the pop/click sounds like it you just turned on an amp, like a surge...
