Windows 7: Sound/External Mic Levels Keep Returning to 100
14 Jul 2010   #1
lyndaaug
I'm using a headset as an external mic with Dragon Naturally Speaking and Eclipse voice recognition software. Ever since getting this new laptop with Windows 7, I've tried adjusting the recording volume level of the external mic. I move it down to 50 or so, and the software works much better, but for some reason, I can't set it to stay at that level.
Here are the two places I've tried doing this:
Under Control Panel, I click on Hardware and Sound, then click on Sound, then click on Recording, then on External Mic Property Levels. I set it to 50 and click OK. There is an "Apply" button, but it does not allow me to click it.
Then, I go under Control Panel, Realtek HD Audio Manager, then External Mic, then Recording Volume, and I move it to 50. I click OK because, again, the "Apply" button doesn't work for some reason.
I need BOTH of these levels down to 50 for my software to work properly, but for some reason and at some random time, the levels inevitably return back to 100.
I am not very computer savvy, obviously, but I've tried finding answers elsewhere and am at my wit's end. Please advise if you have any suggestions. Thanks!
14 Jul 2010   #2
Aphelion
Windows 7 Home Premium
Quote   Quote: Originally Posted by lyndaaug View Post
I would look for level controls in the two pieces of software you mention.
It's very possible they have default "Input" (or Mic) levels and are set at full volume.
Also right clicking on the Microsoft speaker icon in the taskbar will give you a different view of the Realtek controls. I find it clearer than the Realtek control panel.
Ap
15 Jul 2010   #3
lyndaaug
Thank you for your quick response and suggestions. I have checked with the software's settings, and they seem to be fine. I just don't get why the levels keep returning to 100 and why I can't get the "Apply" button to be an option when trying to make the change permanent.
Again, thanks for your help, and if anyone else has any further ideas, I'm all ears!
15 Jul 2010   #4
Aphelion
Sorry those ideas didn't help, normally the set volumes you're speaking of stay in place once set. The only thing I can think of is that one of your software programs "initializes" the audio device which sets the levels to full.
One way to check this idea. Set both volumes to 50 before opening either of the two software packages you use.
Next, open Dragon, then check the volume levels, if no change close Dragon, make sure the levels are still on 50% then open Eclipse and check the volume levels.
As for the apply button, it never activates for just volume changes, doesn't on my system and I'm pretty sure it never has.
There'a another place to see individual level controls, with Dragon and Eclipse running, left click (single click) on the Microsoft speaker icon in the system tray and select "Mixer" at the bottom.
Also, under recording devices... look at the communication tab, select "Do Nothing"
That's all I got!
Ap
18 Jul 2010   #5
lyndaaug
update
Thank you, Ap. I really appreciate your help. I tried setting the levels to 50 before opening Dragon, then Eclipse, but the levels return back to 50 once I open them. I see the speaker levels from the Microsoft tray, so thanks for that hint.
I have one follow-up question for you. It's probably a dumb one, but I can't figure out where to find the "recording devices" you referred to. I'd like to try your "do nothing" suggestion, but I can't figure out where to go. I am sure it's obvious and I'm overlooking it, but I'd love to give it a shot!
Again, thanks for taking the time to help!
Lynda
04 Sep 2011   #6
ghost writer
windows7 pro 64bit
I am running into the same problem with microphone levels, but with Windows Speech Recognition
Tried a USB headset and a headset with standard audio plugs - same problem.
Like you my system is Win7 and I have Realtek HD Audio Manager.
I did see on another forum that registry settings for volume and snr were failing to update correctly, but that is past my level of expertise
Audio files with different sound levels.
Basically what my problem is that some mp3 files that I have on my Windows Lumia 720 phone are very low on sound when play them and yeah my question is how can one song be louder than the another? Uh don't if I posted this in the right sub-forum. Boris out.
Music, Pictures & Video
changing sound levels on multiple video's at once
hey guys ok basically, i have 11-12 videos, and most of them are on the exact same sound level besides 2-3 videos which are extremely loud i want a way to change all of them to the same sound level, without changing the video format, nor video quality
Sound Levels Acting Up
I just got done building a new computer using this MSI motherboard (Newegg.com - MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard) and the sound levels on this thing are simply garbage. So, from another post here on the SevenForums, someone mentioned that I should try...
Sound Levels Constantly Changing on their own
Ok, I need a little help here. Lately, I have noticed that my sound levels in my Volume Mixer keep lowering to the lowest level. I have an ASUS Rampage II Extreme MOBO that came with a Creative Sound Blaster X-Fi MB PCI-E Sound card. The problem is, when I'm in a game or anything else, my...
W7 x64 - poor sound levels
Hi people! When I install latest Realtek drivers I'm getting 50% lowest sound than I had before I've formatted my OS, also the same version of drivers and OS. I'm running W7 x64 and Asus P5Q - PRO mb. When I uninstall them and install "default Windows7 Realtek HD drivers" sound is great and...
