Sound Recorder
  1. Posts : 713
    Windows 7 Pro
    Sound Recorder
    The Sound Recorder that comes with Windows 7 really sucks. It only records and as far as I can see it will not allow editing. It also will NOT save as wav files.
    I learned this trick a long time ago. From Windows XP I copied the sound recorder file and pasted it to Win 7. This works fine except I have a memory issue because I have to much memory.
    When I go to edit a wav file, such as:
    When I select an option such as "Delete before current position" I get the following message:
    According to Microsoft this will happen with any pc with more than 2 gb of memory.
    Does anyone know of a fix for this other than removing memory?
  2. MK2
    7
    Maybe an option is to use another program.
    A very good program is Audacity, it's free, it records wav files and you have loads of editing options.
    You can find it here: Audacity: Free Audio Editor and Recorder
    MK2
  3. Posts : 654
    .....to force Sound Recorder to save as WAV, the user must start Sound Recorder with the command line "soundrecorder /file outputfile.wav"
    from the wiki.
    EDIT: type it without the quotation marks, it will ask for a place to save the file when u have finished recording. Oh and this is for the win7 sound recorder.
  4. Posts : 713
    Windows 7 Pro
    Thanks for the replies .
    I agree that Audacity is a good program, but I don't believe it will save or convert into the (wav) formats that the XP Sound Record is capable of. I will give it another shot and see.
    good to know, but still it will not edit.
    I still want to know if there is a way around or a fix for the 2gb rule for the XP Sound Recorder.
  5. Posts : 3
    Windows 7 home premium 64 bit
    I have been trying to save a sound recorded file in wav format for sometime now. I tried the command prompt with no luck. A friend even sent me the sound files in wav but still could not use it, as it showed up as wav.wpl whatever that is. I just need to convert the file to wav format as I need to upload it on a website that supports wav format only for audio playback. Please help
  6. Posts : 3
    I forgot to add I am using windows 7 home premium 64 bit if this helps
  7. Posts : 713
    Windows 7 Pro
    If you want to extract the audio from mpg, wma etc, I use DVDVideoSoft :
    Free Video to MP3 Converter: How to extract audio from video to MP3
    The audio is in wav format then I use Audacity to edit the audio to the way I want it.
    Good luck
  8. Posts : 3
    I'll try the dvd/videosoft audio , but I also tried to download Audacity with no luck, it took me to something different, never could find the page it showed.
  9. Posts : 1
    Windows 7 x64
    I know this is an old thread, but I had the memory problem on my Windows XP machine too but it seemed to work ok when I was using up a bunch of memory with other programs.
