System Protection not working in System Control Panel
  1. Posts : 4
    windows 7 64 bit
    I've tried to open System Protection in System in the Control Panel but it will not work. It gives an error of 0x81000203. I've rebooted and attempted but get the same thing each time.
  2. Posts : 8,608
    Windows 7 Ultimate 32bit SP1
    Follow instructions on this page error code 0x81000203__ - Microsoft Community
    Scroll to the 2nd answer by Meghmala
  3. Posts : 2,470
    Windows 7 Home Premium
    sec2709,
    Also, let's take a look at what is going on with your system...
    Please download RogueKiller:
    Tlcharger RogueKiller (Site Officiel)
    When you get to the website, go to where it says:
    (Download link) Lien de téléchargement:
    Select the version that applies to your system: x64
    Click the dark-blue button that applies to download.
    Save to the Desktop
    Close all windows and browsers
    Right-click RogueKiller and select 'Run as Administrator'
    Press: SCAN
    A report opens on the Desktop: RKreport.txt
    Please provide the RKreport.txt (Mode: Scan) in your reply.
    (Please do not delete anything!)
    Also, download Farbar Service Scanner
    Save to the Desktop
    • Make sure the following options are checked:
      • Internet Services
      • Windows Firewall
      • System Restore
      • Security Center
      • Windows Update
      • Windows Defender
    • Press: Scan
    • FSS creates a log, FSS.txt, on the Desktop.
    Please provide the FSS.txt in your reply.
  4. Posts : 4
    windows 7 64 bit
    Fixed
    Thanks much!
  5. Posts : 8,608
    How did you fix the problem?
  6. Posts : 4
    windows 7 64 bit
    Removed a program titled "Tune Up 2013". It had many components but would not allow me to dis-engage it, which irritated me, so I removed it and then my system protection worked fine.
    thank you so much!
  7. Posts : 8,608
    Very good!
