Ok so Im a little tight on budget and i need to decide which display should i go with! Both displays are Full HD 1080p and my mainly I'll be doing gaming and browsing that is what i do mostly on PC.
The ASUS is expensive but has 2x HDMI + VGA + Built-In Speakers and Dell has no HDMI but comes with Displayport 1.2a, DVI and no Speakers but cost less. Help me decide which one to buy!
Windows 10 ProCore i5 9600KCorsair Vengeance Pro 2x 8GB (16GB) 3200MHz DDR4MSI GTX 1070 Gaming X 8GB
Corsair MM300 Extended Anti-Fray Mouse Pad | Edifier C2 2.1ch Sound System | XBOX One S Controller | XBOX 360 Wireless Controller for Windows | APC SUA1000i Smart-UPS | PS4 Slim 500GB [Region 1 - USA]
I believe the asus is better although does not have a display port as you already pointed out the refresh rate is superior
Contrast ratio is also undeniably better.
Custom assembled by me :}
Win-7-Pro64bit 7-H-Prem-64bit
