Help with performance information and tools - Advanced System Info
sstowell
8:37 AM
I am curious about the Windows Error Reporting under the Software category in System Information from the control panel Performance Information & Tools Advanced System Information.
I see quite a few errors, which I don't recall seeing in exhaustive searches through all the Event Logs. But no idea if these are pertinent or useful, or how to save or print this report, etc. I have not found anything useful on online about this particular error reporting.
Note that my even finding this info is due to my having many system crashes BlackSOD, new GraySOD, etc. for weeks now, with no useful errors in the Event Log, no diagnostics report significant errors (only driver performance delays from standby mode, which I don't even notice). I am resisting a reinstall of Windows 7 until I get another hard drive, and still hoping to find a simple manageable cause for my problems.
Windows 7 Home Premium 64bitAMD Phenom II X4 B55 3.2 GHz8 GBATI Radeon HD 4250
8 GB
ATI Radeon HD 4250
Have you tried a basic registry cleaner like CCLeaner? Bad drivers can very hard to find - I've never had much luck with Windows error reporting myself. The time it takes to sleuth it and fix it, is less than the time it takes to restore or reinstall.
7 x64 UltimateAMD Ryzen 516GB DDR4Radeon R7 360
7 x64 Ultimate
AMD Ryzen 5
Gigabyte GA-AB350-Gaming
16GB DDR4
Radeon R7 360
2 x Dell U2518D
2560x1440 2560x1440
WD 500GB x2
Samsung SSD 128MB (OS)
XPG SX8200 Pro M.2 2280 1TB
Antec 500
Hyper 212 EVO
Logitech cordless K800
Logitech M510
Avira
Thank you, I think I have tried almost everything... including getting some help with minidump info. A disk check two months ago cleared up the BlueSOD, but not the black screen or the (new) grey grid screen crashes that are becoming more frequent. These may correlate with photo/image viewing or manipulation (but that may be just my perception). I am planning a reinstall of Windows when the new hard disk arrives. Next plan, as my system is a bit old, is a new video card? and/or a new motherboard ... aargh!
8 GB
ATI Radeon HD 4250
Windows 10 ProAMD Ryzen 5 2400G Processor with Radeon RX Ve...G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-P...2047MB NVIDIA GeForce GTX 1060 6GB (EVGA)
Windows 10 Pro
Motherboard Built in
Wired Dell keyboard
Wireless Logitech mouse
250mb down, 30mb up
Panda Cloud Antivirus
Chrome-ish x64
Actually no BSOD, just black screens, hung, no dumps
My problem is not actually Blue SOD, but black SOD :-(
I am getting a black screen frequently, seems to be when using either Windows Photo Viewer (via Explorer "Preview") OR Corel PSP X5 my image s/w of choice.
System is hung, does not respond to Ctrl-Alt-Del, etc. Generally I have to recycle power and restart. There are no error events in the system log prior to shutdown (& often no info or other events for 4-10 minutes prior to black screen), but at reboot I get an error that indicates an unexpected shutdown at approx. the time of the black screen. No other information, and NO dump files.
8 GB
ATI Radeon HD 4250
Black screens may be connected to power save sleep
After some further consideration, and desperation, I tried turning OFF all system power saving sleep. And VOILA, no black screens for 36 hours! There was nothing in logs about power saving sleep... and just the references to unexpected shutdown on reboots, so this was certainly not a case of normal power saving sleep which logs a standard series of info msgs. But I will take what I can get...
8 GB
ATI Radeon HD 4250
