Monitors and sound cut out, fans and HDDs kept running, had to hard re
thready
2:26 AM
You can find me in St. Louie
Both monitors and my external Sound Blaster Omni cut out, power light stayed on, hdd lights kept flashing like normal, fans stayed on. I had to press the reset button to get my PC back and it went through the typical "This computer did not shut off properly" screen before logging into Windows.
When I clicked "Grab All" on the tool, it said it could not retrieve the dump file. I have no idea why. This is all it would collect.
Win 7 Home Premium x64AMD FX 83508 GB 1600R9 280X
custom build
AMD FX 8350
M5A97 LE R 2.0
8 GB 1600
R9 280X
Soundblaster Omni USB Soundcard
Viewsonic 21.5 inch LED
OCZ Vertex 4 120G SSD (boot drive)
Crucial 256G SSD
WD Black 2 TB HDD
Seagate 1TB HDD
Antec Earthwatts Green 650W
Cooler Master HAF 922
5 fans of different brands (3 intake, 2 exhaust) for dust co
Corsair Vengance K70 MX Brown, Razer Orbweaver
Razer Naga
60 Mbps
Webroot Secure Anywhere
I also discovered the joy of dust filters on my intake fans. Thank you Internet.
Windows 10 Proi5-650016GB DDR4 2133 Crucial Ballistix Sport LTMSI GeForce GTX 1060 GAMING X 6G
Custom build
Windows 10 Pro
i5-6500
Gigabyte B150-HD3P-CF
Intel Display Audio
Liyama ProLite XB2483HSU-B2
Crucial MX200 500GB & Toshiba DT01ACA300 3TB
Corsair RM550x
Fractal Design Define S
Cooler Master TX3 i
Func KB-460 (MX Red)
Corsair Gaming M65 RGB
Bitdefender Total Security 2016 + MBAM Pro + MBAE Pro
Creative Sound Blaster Tactic3D Rage V2 headset
Everything is set up to create kernel dumps. Perhaps it didn't BSOD on me, but it simply turned off the monitors and sound. In that case it wouldn't create a dump would it? Maybe it just went into sleep mode by itself. Everything inside the computer was still running which is what is confusing.
custom build
AMD FX 8350
M5A97 LE R 2.0
8 GB 1600
R9 280X
Crucial 256G SSD
WD Black 2 TB HDD
Seagate 1TB HDD
Razer Naga
60 Mbps
Custom build
Windows 10 Pro
i5-6500
Intel Display Audio
Corsair RM550x
Cooler Master TX3 i
