I have since added an old IDE drive to my W7 PC. When I right-click a file to delete it, on the right-click context popup menu, there is a little blue/yellow shield next to delete and rename. This shield is NOT present on the SATA W7 drive.
So, I read and find that if you right-click Recycling Bin, there's an option to prompt the delete confirmation dialog. It was already checked. But, the Bin had stuff in it so I emptied it.
Now when I right-click on the IDE drive, it still has the little blue/yellow but at least I get the delete confirmation prompt.
This is likely the first time I've delete something from the IDE drive AND emptied the Recycling bin.\
I assume the shield has something to dow with security/permissions for the drive itself. What might I check or modify? Or, just leave the IDE drive as with the shield?
- Computer type
- PC/Desktop
- Custom
- Windows 7
- AMD Phenom II X2 (dual-core)
- Motherboard
- GA-MA785GM-US2H
- 4G
- Graphics Card(s)
- integrated ATI HD 4200
- Sound Card
- integrated
- Monitor(s) Displays
- Samsung 24"
- Screen Resolution
- 1920x1080
- Hard Drives
- 1 SSD - Samsung 840 - 500 GB - OS and DATA partitions
1 SSD - Intel 320 - 120 GB (used for backups) - Misc/BACKUP
1 SATA HD - WD, 500 GB - BACKUP
- PSU
- Ultra X4 500W
- Case
- Ultra X-blaster
- Keyboard
- Microsoft Digital Media Pro
- Mouse
- Logitech WIRED!
- Internet Speed
- 15 Mbps FIOS
