Sound Problem Please Help Realtek related
ttaannkk
7:40 AM
After installing Win 7 i have not been able to have sound on this computer period. I have installed several drivers from downloading from the realtek website or through windows updates with no success.
First off this is what i am working with:
ECS PT880PRO-A
Onboard Audio - Realtek ALC655 / 6 channels
Within windows it does not seem there is a problem. No problems in device manager. Sound icon is present in the taskbar. When playback devices is selected and there is a song playing through VLC there is activity in the bar next to where it shows the audio device. Volume is not muted and is 100%.
I had no problem in XP/Vista. I also do have sound when i plug in my USB Logitech headset but i only have one set and i use it for my main computer not the living room PC.
Any ideas or suggestions?
Thank you in advance.
:huh:
Win7 32bit
I had a similar problem
I had a similar problem, I solved it by installing the realtek driver. In the realtek manager the 'Analog' back panel controls, right click and select connector retasking. Mine defaulted to two plugs for the back channel and no plugs for the front channel.
Hope it helps.
Captain Logic Design Works
Windows 7 Ultimate 64
Intel Core 2 Duo E8400 @ 3GHz
Gigabyte EP35-DS3R
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 PCI Expr
On-board
Primary:Acer H213H 21.5" Secondary:Sony old lcd
Primary 1920.1080 Secondary 1280.768
Primary: WD 500 GB SATA "Green"
Secondary: WD 320 GB PATA
APEX SL-8600EPS 600W ATX12V / EPS12V
LIAN LI PC-A05B Black Aluminum ATX Mid Tower
Logitech G510
LX8
Comcast 7Mb/768Kb
