Password - Require on Wakeup
Page 2 of 4 FirstFirst 1234 LastLast
  1. Posts : 72,082
    Hello Jackal, and welcome to Seven Forums.
    If not, just let us know. :)
  2. Posts : 19
    Is it just me of does Windows 7 have the worst Sleep/Hibernation modes?
    I was able to change the Password on wake to "No", but I still have problems with both the Sleep and Hibernation modes. Neither turns the pc "off". I still hear the fans running and the light around the volume knob is still on. The TV display turned off when it was suppose to. I can't even remember which method I was trying at the time but it would not come back on. I eventually had to turn off the PSU and then reboot to get the display back.
    I was able to record a TV program on the SageTV schedule but I still couldn't wake the PC from the Hibernation mode until I cycled the PSU. If I manually put the PC into Sleep, then I could wake it from the keyboard or mouse. But just letting the PC sit to go into Sleep mode wouldn't happen.
    I'm using the RC 7100 build. It's the weekend so I'll have some more time to try out some more configurations when I get home this evening.
  3. Posts : 419
    Windows 7 Ultimate SP1 64- bit
       #12
    I adjusted my settings to 'no',however, it still asks me for a password!
    Any suggestions?
  4. Posts : 72,082
    Hello Seven,
    Double check your "Screen Saver" settings to make sure that the On resume, display logon screen option is unchecked as well. This can give you a log on screen as well if the computer went to sleep after the screen saver was running.
  5. Posts : 419
       #14
    Brink said:
    Hello Seven,
    I solved this problem by selecting the 'Active' setting in the dropdown menu!
  6. Posts : 72,082
       #15
    I'm happy to hear that you got it sorted Seven. :)
  7. Posts : 1
    W7
       #16
    Just joined to post on this topic but this seems a great source of info. Whenever I've been Googling questions it seems here the answer is.... :)
    Q: Is there a registry tweak to apply to achieve disabling password on resume from wakeup?
    I have 4 machines at home and usually build my own unattended install disk to get them set up the way I like. A registry tweak would be nice as I can apply a pile of them in one file and fix those things I need.
    Thanks guys n gals
  8. Posts : 1
    scrfix said:
    Hello,
    I am utilizing the command line for this. In Vista, you have to know the profile name or GUID before you can edit the setting.
    I know that I can get that by utilizing powercfg -getactivescheme however when I do that I get returned:
    Power Scheme GUID: 49ef8fc0-bb7f-488e-b6a0-f1fc77ec649b (Dell Recommended) which will be different for every computer.
    All I need is the 49ef8fc0-bb7f-488e-b6a0-f1fc77ec649b
    How would I capture just that in a variable?
    I was thinking about the following code however it comes back as missing an operand. Any help would be much appreciated.
    @echo off
    For /F "Tokens=*" %%A In ('powercfg -getactivescheme^|Findstr /I /C:": "') Do Set /A _ActiveScheme=%%B
    powercfg -SETACVALUEINDEX %_ActiveScheme% SUB_NONE CONSOLELOCK 0
    powercfg -SETDCVALUEINDEX %_ActiveScheme% SUB_NONE CONSOLELOCK 0
    Wayne Leiser, CTO
    Spectacular Computer Repair
    Hi scrfix - I use the vbs function below to extract the GUID from the line of text you have. It uses VB regex to pull the GUID:
    Function GetGUID(inStr)
        'Extracts the GUID from the line in which it is embedded
        Set regEx = New RegExp
        regEx.Pattern = "[0-9a-f]+\-[0-9a-f]+\-[0-9a-f]+\-[0-9a-f]+\-[0-9a-f]+"
        regEx.IgnoreCase = True
        regEx.Global = True
        Set Matches = regEx.Execute(inStr)
        For Each Match in Matches
            'msgbox("Match " & I & " " & Match.Value)
            GetGUID = Match.Value
        Next
    End Function
    Hopefully 9 months later you're still looking for this.
  9. Posts : 2
    Hello, I'm wondering if W7 supports a more fine-grained configuration: have password on wakeup from sleep, but not on wakeup from hibernation. This is because I already have a password prompt from Truectrypt, so asking for the password again is just redundant.
  10. Posts : 1,519
    El Capitan / Windows 10
       #19
    I'm assuming you're using truecrypt because your version of Windows does not support the superior Bitlocker?
