Hardware - Stress Test With Prime95
  1. Posts : 12,177
       #20
    Check you BIOS temps, the CPU will cool down quickly so it is just an indication of the temps.
    Also use Core Temp and Speed Fan to check against Real Temp.
    It's not unusual to have different readings but, they should be fairly close.
    I wouldn't recommend going past 78°C on any test, you should find out why the temps are so high.
    If they are due to OC or CPU cooler problems.
    I'll take a look at your thread.
  2. Posts : 38
    ^^^ hey can i setup one of these temp monitor programs to run in the background while the CPU stress test runs so that if it overheats it shuts down the computer / saves the hardware from any damage? really dont want to sit next to my PC for 6 hours if at all possible :~)
  3. Posts : 13,354
    Windows 7 Professional x64
       #22
    Hello Kaizer,
    I don't know of any programs that will do that off the top of my head, but in reality, you only need to watch the program for the first 5 or 10 minutes. After that time, your system will be just about as hot as it's going to get, so you can walk away for the rest of the time.
  4. Posts : 2,393
    Microsoft Windows 7 Ultimate: x64 (SP1)
       #23
    Very interesting software I have to say. Thank you for this tutorial Jonathan!
    Best Regards,
    FredeGail
  5. Posts : 4
    Windows 7 64-bit Home Premium
       #24
    Single Core Test
    smarteyeball said:
    Don't forget to tick the 'Round off checking' option under Advanced:
    Attachment 87940
    Otherwise you won't know if one of your cores has failed etc
    (And I personally prefer Realtemp over Speedfan, but that's just my opinion)
    Hello if I am testing a single core processor can I leave 'Round off checking' alone?
  6. Posts : 13,354
       #25
    lucent said:
    Attachment 87940
    Hello lucent,
    That's completely fine. :)
  7. Posts : 4
       #26
    Thanks bud!
  8. Posts : 960
    Windows 7 Ultimate SP1 - 64 Bit
       #27
    I ran Prime95, 2 minutes later, some of them had a fire Icon on :S on Speedfan
  9. Posts : 12,364
    8 Pro x64
       #28
    It's the temps that are more important than the icons.
    I'm assuming you're on stock cooling?
  10. Posts : 960
       #29
    Yes, No Overclocks, etc, I did change the fan speeds and core speeds in SpeedFan, but then immediately reset them.
    And I haven't opened the case at all so no upgrades.
