#40
Use task manage and check if all threads are under 100% load when the Prime95 test is running. If it's under 100% load then it is running.
Check out Advanced and or Options at the top of the page. Make a selection.
Then open RealTemp and watch the load and temps.
Jack
The CPU test seems to be alright. I'll have to check on my system if I get the same RAM usage too.
EDIT: I just want to ask if you selected the Blend test in Prime95? It uses somewhat bigger percentage of RAM to my system (Almost all).
NO my CPU maxed at 100% and he RAM a constant 98.6% and I ran the torture test temps never got above 60C and although Tjunc is 72.5C or something at least the cooling is working fine.
But am now stumped as to what my main problem is I cannot think of anything else to test
ok it looks like you chose the Blend test which stresses the CPU and the RAM. The temps look OK too.
Have you tried changing drives? I'm also running out of idea :X
Yep Roaster mate this is the third in approx 2 months with each OS anyway I have put otu feelers here
New motherboard and CPU - Windows 10 Forums for ideas on a new mobo and CPU as I have simply had it now with this one.
