Video Card - Stress Test with Furmark
Page 5 of 7 FirstFirst ... 34567 LastLast
  1. Posts : 13,354
    Windows 7 Professional x64
       #40
    Hello mate,
    It looks like you have Dynamic Background enabled. That's fine, but if you want to be able to detect defects better, try disabling it.
  2. Posts : 297
       #41
    This only tests the GPU at the OpenGL level. Unfortunately, most games aren't coded for OpenGL but are coded for DirectX instead. Are there GPU benchmarks for that?
  3. Posts : 13,354
       #42
    That I don't know...I'm sorry.
  4. NoN
       #43
    FurMark 1.10.1 Released
    Thanks for that mini tuto!
  5. Posts : 72,063
       #44
    Thank you NoN. The link in the tutorial has been updated for the new version. :)
  6. NoN
       #45
    You're welcome and this little soft works pretty well!
  7. NoN
       #46
    Humm, they updated again...
    Version 1.10.2
    "A maintenance release of Furmark is ready for your GPU burning sessions. FurMark 1.10.2 brings the support of GeForce GTX 660 / GTX 650, as well as some updates (ZoomGPU 1.8.7, GPZU Shark 0.6.6 and GPU-Z 0.6.4)".
  8. Posts : 72,063
       #47
    Thank you NoN. Link updated to the homepage instead now so we no longer have to worry about it. :)
  9. Posts : 28
    Windows 7 Ultimate 64bit
       #48
    When I have log gpu temp enabled it stops working any idea how to fix this?
  10. Posts : 13
    windows server 2012 R2 Standard
       #49
    Good job!
