#40
Hello mate,
It looks like you have Dynamic Background enabled. That's fine, but if you want to be able to detect defects better, try disabling it.
Hello mate,
This only tests the GPU at the OpenGL level. Unfortunately, most games aren't coded for OpenGL but are coded for DirectX instead. Are there GPU benchmarks for that?
Humm, they updated again...
Version 1.10.2
"A maintenance release of Furmark is ready for your GPU burning sessions. FurMark 1.10.2 brings the support of GeForce GTX 660 / GTX 650, as well as some updates (ZoomGPU 1.8.7, GPZU Shark 0.6.6 and GPU-Z 0.6.4)".
Thank you NoN. Link updated to the homepage instead now so we no longer have to worry about it. :)
When I have log gpu temp enabled it stops working any idea how to fix this?
Good job!
