Speech Recognition - Language Configuration is Not Supported Error Fix
    How to Fix the Speech Recognition "Language Configuration is Not Supported" Error
    This tutorial will help show you a few solutions that can be done to fix when you try to start Speech Recognition and get the error message below.
    Speech Recognition could not start because the language configuration is not supported.
    The recognizer language must match the language of the user interface. Please change the recognizer language in the Speech Recognition control panel under Advanced Options.
    One or more of the solutions below may need to be applied to fix this error message. Start with SOLUTION 1 and work your way down, and stop when the error is fixed and stops displaying when you start Speech Recognition.
    SOLUTION 1
    Add ctfmon.exe to Run at Startup
    NOTE: You must be logged in as an administrator to be able to do this solution.
    1. To Add "ctfmon.exe" to Run at Startup
    NOTE: This is the option you need to do to try and fix the error.
    Run_ctfmon_at_Startup.reg
    B) Go to step 3.
    2. To Undo and Remove "ctfmon.exe"from Running at Startup
    NOTE: Just because I always add an undo option.
    Undo_Run_ctfmon_at_Startup.reg
    3. Click on Save and save the .reg file to the desktop.
    5. When prompted, click on Run, Yes (UAC-Windows 7) or Continue (UAC-Vista), Yes, and OK.
    6. Restart the computer to apply.
    7. You can now delete the downloaded .reg file if you like.
    SOLUTION 2
    Verify and Set Correct Speech Properties Language Locale
    1. Open the Control Panel (icons view), click on the Speech Recognition icon, and click on the Advanced speech options link in the left pane. (see screenshot below)
    Speech Recognition - Language Configuration is Not Supported Error Fix-step1.jpg
    2. Verify and make sure that the Language is set to the correct locale (ex: English-US), and that the Review documents box is unchecked. (see screenshot below)
    Speech Recognition - Language Configuration is Not Supported Error Fix-step2.jpg
    3. Make any needed changes, and click on OK. (see screenshot above)
    SOLUTION 3
    Toggle Region and Language Current Location Setting
    1. Open the Control Panel (icons view), click on the Region and Language icon.
    2. Click on the Location tab, select any different location, click on OK, and restart the computer. (see screenshot below)
    Speech Recognition - Language Configuration is Not Supported Error Fix-step3.png
    3. After the computer restarts, change the location back to your correct location (ex: United States), click on OK, and restart the computer again.. (see screenshot above)
    SOLUTION 4
    Create New Speech Recognition Profile
    NOTE: This is if none of the above solutions was able to stop the error message.
    2. Under Recognition Profiles, click on the New button, type in a new profile name, click on OK, and follow the rest of the on-screen instructions to finish setting up a new Speech Recognition profile. (see screenshots below)
    Speech Recognition - Language Configuration is Not Supported Error Fix-step4.jpg
    3. When finshed, check your new profile box to make it the default profile, and click on OK. (see left screenshot below step 2)
  1. Posts : 8,679
    Nice. I'm sure that this will help a lot of members.
  2. Posts : 72,052
    I hope so. :)
  3. Posts : 3
    Windows 7 Ultimate X64
    Thanks Brink. Lovely, solution 1 worked for me.
  4. Posts : 72,052
    You're most welcome 7Human. I'm happy to hear it was able to help. :)
  5. Posts : 1
    windows 7 pro 64-bit
    I have been trying to figure how to get this working off and on for several months. Just came across this thread and got speech recognition working in about 2 minutes, first item got it going.... Thanks for the post..
  6. Posts : 14
    win7 Ultimate 64
    Same goes for me Brink, thanks
  7. Posts : 72,052
    You're most welcome KOREA7. :)
  8. Posts : 1
    hi there! this my first post and i had signed up just because of this. thank you very much! my problem was solved using solution 2. #2 unchecking review documents. KUDOS BRINK! keep it up!
  9. Posts : 72,052
    I'm glad it was able to help Rapmig, and welcome to Seven Forums. :)
