Windows 7: Driver Verifier - Enable and Disable
17 Apr 2012   #20
Jonathan_King
Windows 7 Professional x64
Quote   Quote: Originally Posted by Influx View Post
Hello Jonathan,
Should this be run in Safe Mode?
You can enable Driver Verifier from Safe Mode, but it will not actually run in Safe Mode. Thus, if Driver Verifier is preventing system bootup, you can boot into Safe Mode and disable it. To actually test the drivers, reboot into Normal Mode.
17 Apr 2012   #21
Influx
Win7 Ultimate x64 SP1 / WCP x64 / Ubuntu 11 x64
Quote   Quote: Originally Posted by Jonathan_King View Post
Hello Jonathan,
I did hear someone say that it's meant to be run on safe mode. Thanks for clarifying things up Jonathan.
16 Sep 2012   #22
Dave76
You might consider to add any driver with 'dump' as a prefix to Option one #5, for example; dump_dumpfve.sys and dump_iastor.sys. these should be unchecked also.
They are drivers created to provide disk access during crash dump file generation.
24 Sep 2012   #23
Chronox
Windows 7 Home Premium SP1 32 bit
Quote   Quote: Originally Posted by Dave76 View Post
Wow thanks for the info, I tought I wasnt doing anything wrong.
03 Oct 2012   #24
vincent1028
i've followed all the steps given but i think i ticked dump_dumpfve.sys and dump_iastor.sys.Is it matter?Now i running it for 5 hours already.So should i restart the process?
03 Oct 2012   #25
Dave76
No, I would leave it running.
If Driver Verifier generates a BSOD and blames dump_dumpfve.sys and/or dump_iastor.sys, then disable them and let it run again.
These two drivers aren't blamed very often, but there isn't any necessity to stress them so they don't need to be included in the testing.
11 Nov 2012   #26
hamine
This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification. i tried it again but nothing happened.
What should I do to try and force this to work?
11 Nov 2012   #27
derekimo
Quote   Quote: Originally Posted by EvilOzzmess View Post
This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification... I'm having BSODs though so that could be it.
It's probably working, it just doesn't show anything.
Open a command prompt and enter verifier /query.
Quote   Quote: Originally Posted by hamine View Post
Have a look at the authors response to a previous question like yours.
24 Nov 2012   #28
bash818
vista 64bit
i did this and my computer would lock up everytime i started it up windows would briefly start then log off and lock....why is this?
07 Jul 2013   #29
Raikku
Windows 7 Pro 64bit
I tried to use this and that was impossible because my pc crashed with brief flash of bscreen before Windows even started to load. Had to do recovery in there start screen to get normally in Windows. So this verifier-program seem to be quite hazardous to use.
Multiple BSOD. Driver Verifier Driver caught a driver corrupting
I have had BSOD for a while and being super busy I did not have time to look at it and get it fixed. Well Being a computer guy I assumed I could fix it myself. But with tons of research and trying to use every guide I can find I decided to try here(probably should have came here first). Today I...
BSOD Help and Support
Turbo Boost UI Monitor Driver. Can I disable, or continue let enable?
Hello all, i'm as you can tell a new user to this website, registering at X time today. The reason I started this thread is that I needed some help on a particular driver component that I just don't know how to deal with, lately I've been disabling certain driver's on my machine for any potential...
Hardware & Devices
Wireless Driver Enable & Disable itself
hi my fellow internet frds.. since i while ago my laptop's wireless been behaving really weird.. the wireless driver will suddenly disable and gone from the network list going into Device manager, it says "this driver is not installed " or sth like that... cant exactly rmb what it said, ...
Network & Sharing
Need Knowledge about Driver Verifier
i want to know about Driver Verifier from Windows 7 , is that for monitoring our Driver, but that will make our system stressing or slow right? that Driver Verifier will Damaged our Hardware or our OS System ? Thanks :D:D Regards sle3pingz :cool:
Drivers
BSOD after driver verifier
Plz check, thanks for more infos.... It's ntoskrnl.exe Searching forum and no proper solution. Startup repair doesn't help - can't fix the problem sfc /scann... no errors chkdsk /r ... no errors
