Driver Verifier - Enable and Disable
Page 5 of 5 FirstFirst ... 345
  1. Posts : 1
    Windows 7 Ultimate 64bit
       #40
    Hello,
    I am following the driver verifier instructions, my computer just bsod, i have restarted,
    when into command prompt, typed verifier /query, another prompt popped up with a whole lot of info, then closed.
    How do I find the log file with the driver errors? So i can report back to sevenforums..
  2. Posts : 72,050
       #41
    Hello tigerman,
    You could use the link below to get what you need, and create a new thread in the BSOD forum area to see what we can do to help. :)
    Blue Screen of Death (BSOD) Posting Instructions
  3. Posts : 339
       #42
    Jonathan_King said:
    Yep, you want everything that doesn't say Microsoft, Unknown, or Macrovision.
    Why not the "unknown"s? What if the problem lies there?
  4. Posts : 10
    windows 7 ultimate x64
       #43
    So I been running driver verifier since Id say around 1230-1am. So far no issues, No bsod, No nothing. How am I sure this is running? When I goto command prompt and type verifier /query I got a list of stuff. But I dont see any issues I believ.
    And what does Load and Unload mean in that prompt? Thanks
  5. Posts : 5
    None
       #44
    I did it and it popped up a message saying " No settings where changed" ... is that whats it's suppose to say ?
  6. Posts : 18
    Windows 7 Professional x64 SP1
       #45
    As stated a few times already. If you see a list of stuff it means it IS running.
    AND
    If there are any issues there won't be any warnings but the system will crash (BSOD) and make the dump file in which it will say which driver was responsible for the crash. This dump file should be uploaded per these instructions: Blue Screen of Death (BSOD) Posting Instructions
