Windows 7: Driver Verifier - Enable and Disable
How to Enable or Disable Driver Verifier in Windows 7
Published by Jonathan_King
01 Aug 2010
Contents
information   Information
Driver Verifier runs in the background, "testing" drivers for bugs. If it finds one, a Blue Screen of Death (BSOD) will result; the corresponding dump file will hopefully show the faulty driver.
Driver Verifier - Enable and Disable OPTION ONE Driver Verifier - Enable and Disable
To Enable Driver Verifier
1. Start typing verifier.exe into the start menu, and open Verifier.
2. Select "Create custom settings (for code developers)", and hit Next.
3. Make sure Standard settings, Force pending I/O requests, and IRP Logging are selected, and hit Next.
4. Select "Select driver names From a list", and hit Next.
5. Click on "Provider" at the top to sort the list by manufacturer; select all drivers not provided by Microsoft Corporation.
6. Press Next, and OK to the resulting window.
After a reboot, driver verifier should be enabled. Use your computer as you normally would, although expect frequent BSODs if there are driver issues. If the system doesn't crash after 24 hours, disable driver verifier.
Driver Verifier - Enable and Disable OPTION TWO Driver Verifier - Enable and Disable
To Disable Driver Verifier
2. Select "Delete existing settings"
If you cannot get into Windows to turn off Verifier, try using Safe Mode.
01 Aug 2010   #1
reventon
Windows 7 x64, Windows XP SP3, Fedora
Nicely written!
04 Aug 2010   #2
CarlTR6
Windows 7 Ultimate 32 bit
Very well done, Jonathan. Good clear instructions with illustrations.
04 Aug 2010   #3
theog
ME/XP/Vista/Win7
Nice one, JK.
04 Aug 2010   #4
derekimo
Good one JK, I didn't know that was there.
06 Aug 2010   #5
Jonathan_King
Windows 7 Professional x64
Thanks guys.
08 Aug 2010   #6
EvilOzzmess
7 Ultimate x64 SP1
This didn't work for me. I applied all settings as described, it said I needed to restart so I told it "OK" and nothing happened. I manually restarted, and it just booted up normally without any special screen or status report for the verification... I'm having BSODs though so that could be it.
What should I do to try and force this to work?
08 Aug 2010   #7
Jonathan_King
Quote   Quote: Originally Posted by EvilOzzmess View Post
It's probably working, it just doesn't show anything.
Open a command prompt and enter verifier /query.
22 Sep 2010   #8
Bali
HI JK! UMMM should i verify this drivers too? )= kinda need some help here x.x
22 Sep 2010   #9
Jonathan_King
Yep, you want everything that doesn't say Microsoft, Unknown, or Macrovision.
Multiple BSOD. Driver Verifier Driver caught a driver corrupting
I have had BSOD for a while and being super busy I did not have time to look at it and get it fixed. Well Being a computer guy I assumed I could fix it myself. But with tons of research and trying to use every guide I can find I decided to try here(probably should have came here first). Today I...
BSOD Help and Support
Turbo Boost UI Monitor Driver. Can I disable, or continue let enable?
Hello all, i'm as you can tell a new user to this website, registering at X time today. The reason I started this thread is that I needed some help on a particular driver component that I just don't know how to deal with, lately I've been disabling certain driver's on my machine for any potential...
Hardware & Devices
Wireless Driver Enable & Disable itself
hi my fellow internet frds.. since i while ago my laptop's wireless been behaving really weird.. the wireless driver will suddenly disable and gone from the network list going into Device manager, it says "this driver is not installed " or sth like that... cant exactly rmb what it said, ...
Network & Sharing
Need Knowledge about Driver Verifier
i want to know about Driver Verifier from Windows 7 , is that for monitoring our Driver, but that will make our system stressing or slow right? that Driver Verifier will Damaged our Hardware or our OS System ? Thanks :D:D Regards sle3pingz :cool:
Drivers
BSOD after driver verifier
Plz check, thanks for more infos.... It's ntoskrnl.exe Searching forum and no proper solution. Startup repair doesn't help - can't fix the problem sfc /scann... no errors chkdsk /r ... no errors
