#80
Brink,
Thanks again! Makes me feel better knowing what's going on there.
Brink,
Thanks Shawn,
An old post, but your tip to "... then for next time uncheck Always show all icons and notifications on the taskbar (click on link) box and click on OK. Afterwards check the Always show all icons and notifications on the taskbar box and click on OK. This will toggle these settings off an on to have it work again".
I tried other tips that didn't work. I now have the icon again to "Safely Remove Hardware and Eject Media". Toggling all-on then, off and selecting the one I want to show and toggling on "Show icon and notifications" worked.
Hi Shawn. It's strange, but, the external drive I use for music won't eject. It says that an application is still using it. But it isn't. When I tried to eject it through the Devices & Pinter method, it worked! Two questions: any idea why it works one way & not the other? Second, any idea how to find out what application or service is using it when if fails to eject?
Hello pxfragonard, :)
I'm not sure why one method would eject it and not the other. You could check in Task Manager to see what is running that be holding it up.
I would suspect that it may be the app you were using to listen to the music, or anything that was accessing the drive that could have hanged.
That's what I thought, but the vlc wasn't running. Thanks anyway.
