Processor Name - Change
    How to Change the Displayed Name of the Processor in Windows 7, XP, and Vista
    This short tutorial will teach you how to change your computer's processor's name. For example, before my computer's processor's name was displayed as Core 2 Duo T9600 @ 2.80 GHZ. After the simple hack, I changed the name to i7 @ 2.80GHZ. The processors new hacked name doesnt have to be a name of a real processor, you can name it something silly!
    I have made a video on how to do this step by step, you can watch the video at the bottom of this tutorial .
       Warning
    In this tutorial we will be changing some registry values. Incorrectly following this tutorial could result in a damaged OS. I have done this tutorial myself and haven't experienced any problems.
    Step One: Open up the Registry editor (RegEdit).
    First, click Start, and search RegEdit (Windows 7/Vista). Open up regedit when the search has found it.
    Step Two: On the left hand column in Registry Editor, open HKEY_LOCAL_MACHINE, under it,
    open up: Hardware->DESCRIPTION->System->CentralProcessor->1
    Step Three: Now you can see a few lines of text on your right side in Registry Editor. Double-Click the one that is named "ProcessorNameString". A small box will pop-up, and you can change the processor's name to anything you like. After your done, press enter and close Registry Editor.
    Step Four: Now we will see what we have changed under Windows.
    Open Start, and Right-Click Computer, then click Properties in the Context Menu
    Step Five: You can see your processor name changed to what ever you changed it to :).
    Troubleshooting: If the processor name did not change, Do step one, but on Step Two, instead of going into the number 1, go into number 0, and follow the rest of the Tutorial
    Video: (Sorry for bad quality screen capture )
  1. Posts : 2,737
    Respectfully: The video may be low quality, it is very hard to read the registry keys and see just what you are doing. I even went to YouTube and tried viewing it there with the extra options, even full screen it is difficult to read. Good job on the video like the music and fades.
  2. Posts : 10,200
    Absolutely a waste of time in my opinion.
  3. Posts : 2,963
    What are you talking about. You know how impressed you would be if someone had a i7-980X Extreme Edition with a WEI score of 4.5.
  4. Posts : 10,200
    and you said that with a straight face.
  5. Posts : 2,963
    Was I supposed to?
    BTW Aero, I am not trying to say anything bad about your tutorial at all. Just joking around.
  6. Posts : 49
    Windows 7 Ultimate 64-Bit
    Its okay :). I know the video is extremely bad, so i will be re-making the video.
  7. Posts : 627
    Windows 7 Pro 64 bit
    Why would you want to do this ?
