Gadgets - Restore Default Gadgets
    How to Restore the Default Windows 7 Gadgets
    This will show you how to restore the desktop gadgets that come pre-installed with Windows 7.
    EXAMPLE: Gadgets
    Note: Some gadgets already uninstalled.
    Here's How:
    1. Open the Control Panel (category view), then click on Appearance & Personalization. (See screenshot below)
    2. Click the 'Restore desktop gadgets installed with Windows' button as highlighted in the second image. (See screenshot below)
    Gadgets - Restore Default Gadgets-control-panel-appearance-personalization.png
    3. This will bring up the Desktop Gadgets window with a message stating 'All Windows and administrator installed gadgets have been restored' (See screenshot below)
    4. When finished, just close the Desktop Gadgets and Control Panel windows.
    That's all there is to it
    Jeff
  1. Posts : 296
    Windows 7 baby ! : D
    thanks !
  2. Posts : 521
    Windows 7 Ultimate x64 Service Pack 1
    Will this remove all the other third party gadgets you installed?
  3. Posts : 18,404
    Shouldn't. It's only for the default ones pre-installed with Win 7. Third party ones are usually stored here:
    Username- appdata (a hidden folder) local-Microsoft-Windows Sidebar-gadgets.
    The default ones are here:
    Program Files/Program Files (x86) -
  4. Posts : 521
    Okay. Thanks for the additional information mate. Rep Added
  5. Posts : 18,404
    You're welcome, and thanks. Welcome aboard.
  6. Posts : 1
    Windows 7 Ultimate x86
    Thanks!
    Thanks man! It solved my problem in sidebar gadgets..
  7. Posts : 3
    I did what you and several other sites suggested but I am getting this message "There were no Windows or administrator gadgets to restore"
  8. Posts : 3
    Now I ran the command prompt scan-now and got 'Windows Resource Protection did not find any integrity violations.' I'll subscribe to this thread if that's possible on this forum or website and I'll check back hopefully you all or someone will respond!
  9. Posts : 6,305
    You could try disabling the gadgets then re-enabling them to see if that helps with your issue.
    Gadgets - Enable or Disable
