Karl, thanks for pointing that out. I did not know that. But now I am confused. Maybe we should settle for disque.A small technicality is that a CD/DVD disc is spelled Disc as opposed to Disk. The word Disk being used to refer to such things as a hard drive and disc being used to refer to such things as a CD/DVD
I found this in a Wiki to add to the confusion:
In International English, disk is the correct spelling for magnetic disks. If the medium is optical, the variant disc is usually preferred, although computing is a peculiar field for the term. For instance hard disk and other disk drives are always thusly spelled, yet so are terms like compact discs. Thus, if referring to a physical drive or older media (3" or 5.25" diskettes) the k is used, but c is used for newer (optical based) media.
