Bootmgr is missing - Fix
Page 4 of 10 FirstFirst ... 23456 ... LastLast
  1. Posts : 297
       #30
    Element is missing
    You forget, most people have bootmgr or something on a partition labelled “System Volume Information”. I wasted a whole evening yelling my lungs out at this thing.
    Last edited by HoneycombAG; 10 Jul 2012 at 21:50. Reason: Solved - Element not found
  2. Posts : 178
    Windows 7 Home Premium Service Pack 1 32-bit Build 7601
       #31
    What is the full name of bootmgr?
  3. Posts : 72,051
       #32
    Boot Manager
  4. Posts : 1
    I did these now instead of getting a white cursor I get the messages
    Remove disks or other media.
    Press any key to restart
    I have nothing plugged in so I hit a key and get the following messages
    Reboot and select proper boot device
    Or insert boot media in secured boot device and press a key
    Got any ideas?
    Great tutorial (:
  6. Posts : 2
    Win 7 64 bit
       #35
    uh oh... RebuildBcd?
    hi guys. Love the forum and have been getting a lot of help here today! I destroyed my win7 install this morning by messing with the registry (deleted the wownode entire key, bad idea...) anyhow now it wont start so I have a dell/alienware "repair" cd in there. after trying the steps above to get bootmgr working again, the 1st two were successful, but it's failed on the last step.
    when I type bootrec /RebuildBcd it says, "Total identified Windows installations: 0"
    then if i run repair, it says "Boot manager is missing or corrupt"
    when i restart, it still says "BOOTMGR is missing, ctrl alt del to restart"
    so i'm stuck on the last step - what's RebuildBcd trying to do?
  7. Posts : 2
    Win 7 64 bit
       #36
    hey me again - i found this - Bootrec.exe Tool - How to Use in Windows Recovery Environment and was able to get past the "windows installations: 0" by creating a new BCD. Now it says "windows installations: 1" - so I entered Y and it said that it was successful!
    But, I restarted and it still says Bootmgr is missing :/
    So any thoughts would be awesome! thanks
    Create a new thread, and someone will be able to help you (:
  9. Posts : 1
    windows 7 ulitmate x32
       #38
    thanks it really helpd a lot
  10. Posts : 5
    win7 home premium
       #39
    bootmgr
    after doing these steps it still says the same message
    i also did the following
    bcdedit /export C:\BCD_Backup
    c:
    cd boot
    attrib bcd -s -h -r
    ren c:\boot\bcd bcd.old
    bootrec /RebuildBcd
    but it didnt work so i tried again but it gave me an error that ren c:\boot\bcd bcd.old already exsits
    thanks any help is really appreciated
