#40
Thanks for posting back Dave. Looks like ive got a nice little project on for an easter sunday now.Will have a look at the links you supplied and give it a go.Hi DaveLooks good Jon, I tried the USB installer method and was impressed with the ease of the process.
This can easily be put on a USB and removed when no longer needed.
This led to making a USB rescue drive, which quickly led to approximately 400 apps on 1.44GB.
Including the Windows 7 System Repair Disc and MS Sysinternals Suite.
Most of these will never get used but, it's better to have something when needed than have to look for it.
Im interested in what you have done here.I have about 7-8 1 gig usb sticks with various boot programs on like partition wizard, killdisk, now memtest but its always bothered me that especially in the memest case that it uses only 200kb of space on a 1 gig flash drive.
How do you install more than 1 boot program on 1 flash drive and how does the pc recognise which program you want to use at boot.
I would be very interested in making something along the lines of what you have done.
Danny
Hi Danny,
I am using this:
How to Create the Ultimate Bootable USB Flash Drive
You can add as many ISO programs as you have room for, then edit the loader file to add it to the start list. Works great.
The other one is Liberkey, has a lot of useful apps that come with it, as far as I remember you can't add apps to it, but you can use the free space to store any files you want. I just made a folder for the misc files.
Make sure you have your BIOS set to boot from a USB device, there are usually a couple of choices, try them until you find the right one.
Thanks again
Danny
