RAM - Test with Memtest86+
Page 11 of 14 FirstFirst ... 910111213 ... LastLast
  1. Posts : 28
    windows 7
       #100
    @Britton30
    The graphic capture that you have posted is quite revealing. This is the first time I have seen such detailed info on the ram. I have a Zotac Mini-ITX motherboard with dual core Atom cpu and nVidia chipset. My display is nowhere close to this. May be it is the chipset that is the passing on the fardware information.
  2. Posts : 24,479
    Windows 7 Ultimate X64 SP1
       #101
    That's right, AMD and Intel will have different memtest data shown. The chipset will also have some different ones too.
  3. Posts : 4
       #102
    Question - does the memtest program write a log result to the USB stick once it's done so I can send it to tech support?
  4. Posts : 880
    Windows 7 Professional 64bit
       #103
    I don't believe it does. At least, I have always taken screen shots of the results for communicating errors to Mfr's tech support...
  5. Posts : 4
    This was so easy to understand and follow, even for people like me who know basically nothing about how computers actually work. Thank you so much!!
  6. Posts : 297
    Windows 7 Professional 64-bit (6.1, Build 7601)
       #105
    Have a question for Memtest, is the program just for diagnosing the RAM and show us the errors or it diagnoses the RAM, tells us the results and fixes it?
  7. Posts : 6,830
    Windows 7 Ultimate 32-Bit & Windows 7 Ultimate 64-Bit
       #106
    It only diagnosing the RAM . To fix Ram issues is replacing the ram that is giving the errors . If you have more than one ram installed you test each ram until you find the problematic RAM stick . If you have a kit then you replace both of the sticks .
  8. Posts : 7
    window 7 ultimate 64bit
       #107
    thanks jk
  9. Posts : 14
    Microsoft Windows 7 Ultimate 64 bits 7601 Multiprocessor Free Service Pack 1
       #108
    Hi to everyone in the forum, and thanks for the tutorial Jonathan_King, it was extremely useful to me.
    Well, thereŽs another reason for me posting right now, and that is that I experienced some problems when trying to boot from an usb pendrive, but I managed to boot from it and IŽd like to share what I did for that to happen.
    Like many at first I couldnŽt get it to boot, even after putting the usb device as 1st boot unit. But I realize my Bios, in advance mode, has an option called "boot override", there I just selected the usb with the bootable memetest+86 and it started running inmediatly.
    I hope this can help some people out there.
    So, thanks again for the great guide. Good bye.
    Arsene.
  10. Posts : 11
    Windows 7 Pro 64bit
       #109
    I don't know if anyone noticed, but in the latest Memtest86+ - Advanced Memory Diagnostic Tool, there's no boot file.
    In the Download - Auto-installer for USB Key (Win 9x/2k/xp/7)
