RAM - Test with Memtest86+
Page 14 of 14 FirstFirst ... 4121314
  1. Posts : 19,383
       #130
    No....MemTest86+ will just keep running until you stop it.
  2. Posts : 18
    Windows 7 Professional x64 SP1
       #131
    Thank you for your reply. Ran the test for 38 hours (I can't remember how many passes but quite a lot) and no errors. :)
  3. Posts : 160
    Win 7 64 bit, 6.1.7601 Service Pack 1 Build 7601
       #132
    Hello,
    I downloaded the from your url Auto-installer for USB Key (Win 9x/2k/xp/7) *NEW!*
    I created USB bootable version as described. I find the following files in USB
    04/14/2010  03:31 AM                73 syslinux.cfg
    08/23/2013  08:52 AM           150,024 mt86plus
    04/14/2010  03:17 AM             1,397 Readme.txt
    03/03/2010  06:09 AM            18,339 Copying
                   4 File(s)        169,833 bytes
    I have win 7 64bit has booting issues. Review my thread
    Win 7: Black screen on boot up, before login screen?
    I did changes the BOIS to boot from USB. The above created bootable USB is not working in my laptop.
    What could I do to make this work?
    Thanks for helping.
  4. Posts : 21,004
       #133
    I am just wondering if mention should be made that the slots themselves and therefore by association the motherboard may also be faulty / bad ??
    I have found that some sticks may show up as bad in a particular slot ie slot #1 yet not in another ie slot #2 - it then narrows down the search for the source of the failing memory. It is then apparent that slot #1 is at fault.
  5. Posts : 19,383
       #134
    Thats already described in the tutorial John.
  6. Posts : 21,004
       #135
    Ok Colin I had not seen that before
  7. Posts : 177
    When MemTest starts press c (configuration) select Full Memory Range, and then let it run.
    For VRAM: use Video Memory Stress Test:
    This is a Windows version, but a n FDD version also exists that can be run from a bootable USB.
