DOM Storage "Cookies" - Enable or Disable
    How to Enable or Disable DOM Storage "Cookies" in Internet Explorer and Firefox
    DOM Storage is often compared to HTTP cookies. Like cookies, Web developers can store per-session or domain-specific data as name/value pairs on the client using DOM Storage. However, unlike cookies, DOM Storage makes it easier to control how information stored by one browser window is visible to another.
    DOM Storage is comprised of two primary parts
    • In Session Storage, any data input is stored for the duration of the session. Thus, if a new tab is opened, the data from the Session in the original tab is stored for the new tab.
    • Local Storage, spans multiple windows and persists beyond the current session. Local Storage allows Web applications to store up to 10 MB of user data. This could include data stored offline for later reading
    This tutorial will show you how to enable or disable DOM Storage from being used in Internet Explorer and Firefox.
    For more detailed information about Dom storage, please see: Introduction to DOM Storage
    Special thank you to Corrine for pointing this out in her thread here and post here.
    OPTION ONE
    Enable or Disable DOM Storage in Internet Explorer
    1. Open the Control Panel (icons view), and click/tap on the Internet Options icon.
    A) Go to step 3.
    OR
    2. In Internet Explorer, click/tap on Tools (Menu bar or gear icon) and Internet Options.
    3. Click/tap on the Advanced tab, then scroll down to the Security section under Settings. (see screenshot below)
    4. To Enable DOM Storage
    A) Check the Enable DOM Storage box and click/tap on OK. (see screenshot above)
    5. To Disable DOM Storage
    A) Uncheck the Enable DOM Storage box and click/tap on OK. (see screenshot above)
    OPTION TWO
    Enable or Disable DOM Storage in Firefox
    1. Open Firefox.
    2. Type about:config in the Firefox address bar and press enter. (see screenshot below)
    3. Click/tap on the I'll be careful, I promise button. (see screenshot below)
    4. To Disable DOM Storage
    A) Scroll down a bit and double click/tap on the dom.storage.enabled entry to change the "value" from true (default setting) to false. (see screenshot below)
    WARNING: Be real careful to not double click on any other entry and change it's value.
    5. To Enable DOM Storage
    A) Scroll down a bit and double click/tap on the dom.storage.enabled entry to change the "value" from false to true. (see screenshot below)
  1. Posts : 408
    Windows Seven Home Premium 32bit SP1
    Thank you Shawn & Corrine very enlightening
    BTW it appears Firefox 4b12 default home page must be dependent on Dom storage as the search engine stopped working
  2. Posts : 72,043
    You're welcome Darryl. Glad that we could help.
    Thank you for posting back about Firefox 4b12. :)
  3. Posts : 408
    yeah i just set my home page to https://encrypted.google.com/
  4. Posts : 72,043
    Even better. :)
  5. Posts : 23
    Both 64 & 32 bit home premium editions w/ win 7 upgrades sp1
    I really don't see the point of dom storage for a single user,
    Possibly for an administrator on a network with multiple users...big brother type of oversight,
    But is this really necessary to accumulate a bunch of garbage you really wouldn't know about,
    Most people do not delete their browser history or cookies for that matter :)
    I find it kind of offensive that windows keeps retaining information of transactions even those other setting are set to not save anything, and is set to delete browser history at exit,
    Then I find out one more place to turn off :)
  6. Posts : 20,583
    Win-7-Pro64bit 7-H-Prem-64bit
    Option 4. is a newbie for me/ kinda cool,
    Question though,
    Delete browser history Settings button/ Cache and databases section,
    Wouldn't Unchecking allow.... do the same thing ?
    Cheers.
  7. Posts : 72,043
    Hello Mike,
    Nar, that setting is would be to have or not have that included to be deleted when you deleted your browsing history.
    This tutorial is to turn on or off the DOM storage feature instead. :)
  8. Posts : 20,583
    Hi Brink sorry to be off topic of the tutorial,
    TechNet forum requires DOM storage to be checked in advanced settings otherwise menus and links are unresponsive is the only reason I posted,
    Plus to give thanks for the new way/ via 4,
    Cheers.
  9. Posts : 72,043
    No worries mate. All input is welcomed. :)
