Revo Uninstaller Freeware - Uninstall Programs
    How to Uninstall Programs and their Leftovers using Revo Uninstaller Freeware
    This short video tutorial explains how to uninstall programs with Revo Uninstaller Freeware that also scans for leftovers after the standard uninstall. . Note: If you click the link above the video window, the graphics resolution of the video is much better.
    Revo Uninstaller on Vimeo
  1. Posts : 17,322
    Win 10 Pro x64
    Nice work, Wolfgang.
  2. Posts : 560
    WIN10
    Yes thanks! I was a big fan of Your Uninstaller in XP but that was version 2006 I think. Once I started using Vista, I just used the regular Add/Remove method for uninstalling.
    Now I'm running Windows 7 and I installed Revo Uninstaller yesterday and since I haven't uninstalled anything yet, I will have a great tool when need be.
    The audio in the video is pretty low, but it works.
    Thanks Again, WHS
    Eldin
  3. Posts : 11,990
    Windows 7 Ultimate 32 bit
    Very well done, Wolfgang.
  4. whs
    Thanks Again, WHS
    Eldin
    Right, the audio is low. I tried to boost it, but on this system there seems to be no good way to do that. On my HP in FL I do not have that problem.
    PS: I just played around some more with the boost level and it got a little better. Well, that is for the next tut.
  5. Posts : 1,514
    Win 7 Home Premium SP1 32 bit
    Watch for add ons it will want to install.. use custom install..
  6. whs
    That is a good idea with any program installation. And even then they sometimes smuggle some junk into your system.
