Taskbar - Move Location on Desktop Screen
Page 2 of 2 FirstFirst 12
  1. HDM
    Windows 7 Ultimate x64 (SP1)
    Thanks for the tut mate :)
  2. Posts : 72,061
    Thank you HDM. :)
  3. Posts : 1
    Windows 7 Home Premium 64 bit.
       #12
    donīt worx... :-(((
    Hello..
    Unfortunately here is no of this 3 options working..
    Option 1 gimme no selection..
    Only a gray field..!
    Regards
  4. Posts : 72,061
    Hello GermaniCus, and welcome to Seven Forums.
    Check to see if using OPTION ONE in the tutorial below may be able to help by enabling the ability to move the taskbar location.
    Taskbar - Enable or Disable Moving
  5. Posts : 2
    Win 7 64 bit
       #14
    Taskbar - left side Start button on the bottom??
    selvan777 said:
    I too place the Taskbar on the left but would like all the contents flipped over so the Start button is on the bottom.
    Honestly, I don't understand why Microsoft didn't design it that way!
    I came here looking for a solution to the Taskbar placement. I like it on the left, but can't understand why there isn't an option to have the Start button at the bottom (just seems intuitive to me) .
    Does anyone know of a hack for this?
  6. Posts : 41
    Yup, I'm still waiting too.
  7. Posts : 41
    Has anyone tried this one yet, I have not but did recently hear of it.
    Start Orb Mover: Move your Start Button and Start Menu to different locations
    This portable freeware will now allow you to move the Start Button and the Start Menu to either the center of the Taskbar or far right\bottom, depending on Taskbar location.
  8. Posts : 2
    Win 7 64 bit
       #17
    I tried installing it and it threw an error message that I couldn't easy troubleshoot, so I just restored my system and moved on. I'm using Win7PRo 64-bit, 8GB RAM. Sure would like that Start Button, etc at the bottom left but don't have time to fuss.
  9. Posts : 41
    Same here, trouble with installation. It is the first release and will only get better moving forward.... hopefully.
  10. Posts : 9
    windows 8 X64
       #19
    I really like this site, I didn't realize that Windows 7 had an option to move the taskbar left, right, bottom or top. I kept trying to drag back to the bottom with no success, but as usual the info I needed was here. Thanks again for all the hard work that goes into running this site and getting the correct answer to problems.
    MIKLO
Đ Designer Media Ltd
