Thanks for the tut mate :)
Hello..
Unfortunately here is no of this 3 options working..
Option 1 gimme no selection..
Only a gray field..!
Regards
Hello GermaniCus, and welcome to Seven Forums.
Check to see if using OPTION ONE in the tutorial below may be able to help by enabling the ability to move the taskbar location.
Taskbar - Enable or Disable Moving
Has anyone tried this one yet, I have not but did recently hear of it.
Start Orb Mover: Move your Start Button and Start Menu to different locations
This portable freeware will now allow you to move the Start Button and the Start Menu to either the center of the Taskbar or far right\bottom, depending on Taskbar location.
Same here, trouble with installation. It is the first release and will only get better moving forward.... hopefully.
I really like this site, I didn't realize that Windows 7 had an option to move the taskbar left, right, bottom or top. I kept trying to drag back to the bottom with no success, but as usual the info I needed was here. Thanks again for all the hard work that goes into running this site and getting the correct answer to problems.
MIKLO
