Fonts - Delete
Page 4 of 5 FirstFirst ... 2345 LastLast
  1. Posts : 168
    Windows 10 Home 64b
       #30
    There is an entry in the registry besides that is named HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\FontSubstitutes
    do i have to delete fonts from the list or just the one from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts ???
  2. Posts : 72,041
       #31
    Hello LM,
    You would only delete the font from the Fonts location as in the tutorial. :)
    FontSubstitutes: Core Services
  3. Posts : 168
    Windows 10 Home 64b
       #32
    Followed it and saved a few 260 MB of space without problem yet, superb tutorial.
  4. Posts : 72,041
       #33
    That's great news LM. Thank you for posting back with your results. :)
  5. Posts : 1,002
    XP Pro (x86) | 7 HP (x86) & (x64) | 7 Pro (x64)
       #34
    Are hidden fonts loaded at boot ?
  6. Posts : 72,041
       #35
    Hello Russell,
    Nope. Hidden fonts are not used. :)
  7. Posts : 1,002
       #36
    Thanks Brink
    I thought if I deleted all the hidden font files it might reduce boot time.
    Glad to know hidden fonts are not loaded at boot.
    Russell :)
  8. Posts : 72,041
       #37
    Anytime. :)
  9. Posts : 168
    Windows 10 Home 64b
       #38
    I deleted some fonts from both 32b and 64b font entry and they are not showing anymore in Font folder, but if i access the folder from the command prompt there is a lot of fonts that do not show up in the folder (if looking it via explorer), how can i unhide them?, example the MyriadPro-BoldCondIt.otf
    Attached Thumbnails Attached Thumbnails Fonts - Delete-capture1.jpg   Fonts - Delete-capture2.jpg
  10. Posts : 72,041
       #39
    Hello LM,
    Looks like that font was added by Adobe Reader instead of it being a Windows font.
    You could try searching the C: drive with *.otf to see if it will let you access it that way.
