Welcome Log On Text Message - Change
Page 1 of 18 12311 ... LastLast
    How to Change "Welcome" Text Message at Log On in Vista and Windows 7
    This will show you how to change the Welcome text message you get after a user logs in to Windows 7 and Vista to any text message that you want it to say instead.
    You can only do this tutorial while logged on as an administrator.
    If you run a sfc /scannow command, then you will lose all changes made to the system file in the tutorial below since it and all other system files will be restored back to default by the command.
    For Windows 7 Only:
       Warning
    Making a mistake while modifying system files can render your Windows 7 installation unusable. To be safe, you should create a restore point before doing this tutorial in case you need to do a system restore at boot using the restore point to undo any mistakes that may be made.
    EXAMPLE: Default and Changed "Welcome" Text Message at Log On
    OPTION ONE
    1. In Windows Explorer, navigate to C:\Windows\System32\en-US\winlogon.exe.mui. (see screenshot below)
    The en-US folder is in English Windows 7 copies. If you have a non-English Windows 7 copy, then this folder will have a different name reflecting your language instead.The table below are a few of the most common ones.
    Folder Name Language
    da-DK Danish
    en-GB English-Great Britian
    en-US English-U.S.
    fi-FI Finnish
    fr-FR French
    de-DE German
    el-GR Greek
    it-IT Italian
    no-NO Norwegian
    es-ES Spanish
    sv-SE Swedish
    2. Take ownership of the winlogon.exe.mui file with your user account, and set it's permissions to Allow your user account Full Control. Close Windows Explorer when finished.
    3. Copy this winlogon.exe.mui file to your desktop.
    4. If you have not already, download and install Resource Hacker.
    5. Right click on the Resource Hacker shortcut in Start Menu - All Programs, then click on Run as administrator. (see screenshot below)
    6. If prompted by UAC, then click on Yes (Windows 7) or Continue (Vista).
    7. In Resource Hacker, click on File and Open. (see screenshot below)
    8. In Resource Hacker, select All Files (*.*) in the Files of type drop down box, navigate to and select the copied winlogon.exe.mui file on your desktop, then click on the Open button. (see screenshot below)
    9. In the left pane of Resource Hacker, expand String Table, and 63, to 1033. (see screenshot below)
    10. In the right pane of 1033, replace the Welcome text in quotes at both 1002 and 1005 locations with the text you want instead (ex: Hello) within quotes, then click on the Compile Script button. (see screenshot above and below)
    11. Click on File and Save, then close Resource Hacker. (see screenshot below)
    12. Copy the modified winlogon.exe.mui file on your Desktop, and Paste it into the C:\Windows\System32\en-US folder from step 1. (see screenshot below step 1)
    NOTE: The en-US folder is in English Windows 7 copies. If you have a non-English Windows 7 copy, then this folder will have a different name reflecting your language instead.
    13. Click on Copy and Replace. (see screenshot below)
    14. If prompted, click on Continue (UAC) and Yes to approve.
    15. Open a elevated command prompt, type mcbuilder, press Enter, then close the command prompt. (see screenshot below)
    NOTE: Thanks to Fimble for pointing this out.
    16. Restart the computer.
    17. Restart the computer and log in to see the changes made.
    NOTE: If this does not work for you in Windows 7, then see the NOTE box at the top of the tutorial.
    18. You can delete the winlogon.exe_original.mui that ResHacker created if you like since you can easily do OPTION TWO below to restore the default settings.
    OPTION TWO
    Restore Default "Welcome" Text Message at Log On
    1. Repeat OPTION ONE above, but type Welcome in both locations at step 10 instead.
    Shawn Brink
  1. Posts : 966
    Windows 7 Enterprise
    Nice one again Shawn
  2. Posts : 72,050
    Thank you Matt. :)
  3. Posts : 8,679
    Thanks a lot Brink! This is very cool
  4. Posts : 72,050
    You're most welcome StalkeR. Thank you. :)
  5. Posts : 66
    windows 7
    i can not do it
    Attached Thumbnails Attached Thumbnails Welcome Log On Text Message - Change-untitled.jpg
  6. Posts : 72,050
    Hello Drifking,
    Try the same thing I posted at the link below for your other issue, but substitute the file in this tutorial instead.
    Logging off... Text Message - Change
  7. Posts : 2
    Windows Home Premium 64bit
    Help it won't work for me. When I try to open it with ResHacker, it's just simply not there. When I try to copy it to my desktop Windows says "The file can not be found"
    Help please!
  8. Posts : 72,050
    Hello Tatenforts, and welcome to Seven Forums.
    Double check through the steps to make sure that you did not miss anything in them and are doing it exactly step by step. Be sure that you select All Files (*.*) in the Files of type drop down box at step 7 to be able to see, select, and open the winlogon.exe.mui file in ResHacker.
  9. Posts : 1,036
    Winbdows 7 ultimate x64 | Ubuntu 12.04 x64 LTS
    Shawn, Nice tutorial. But here's a problem similar to Tatenforts. I'm quite sure I've taken its ownership and ran Resource hacker as admin but no luck. It and even winload.exe.mui simply don't appear in the list.
    What to do? Will Ive to use admin account, but this will make changes to the admin acc. only, no?
