Thumbnail Cache - Clear and Reset
Page 5 of 6 FirstFirst ... 3456 LastLast
  1. Posts : 72,062
       #40
    Jez2k said:
    My Waterfox shortcut on the desktop is still completely black. I tried the batch file, no luck. I loaded Disk Cleanup but the option to clear the thumbnail cache is not there. No luck with CCleaner either.
    EDIT
    And now, the CCleaner shortcut itself is all black, along with the IObit Uninstaller icon.
    EDIT
    Each time I create a new shortcut on the desktop, it immediately turns black.
    Hello Jez2k, :)
    Does this affect shortcuts at other locations as well?
    Did you change your shortcut arrow overlay icon? If so, it may be causing a black overlay on the shortcut icon if it doesn't like the replacement for the arrow.
    Shortcut Arrow - Change, Remove, or Restore - Windows 7 Help Forums
  2. Posts : 150
    Triple Boot - Win 10 x64Pro + Win 7 x64 Ultimate + WinXP-mce x1
       #41
    Captain Zero said:
    Yet another awesome tutorial. Kudos Brink!
    +1
    Yup!
    Brink's tutorials make me feel like I've got the upper hand on this beastie I call my computer
  3. Posts : 26
    Windows 7 Professional x64
       #42
    It affects any shortcut in any location, even in a window with view set to details.
    Yes I used the shortcut arrow hack reg and I tried the remove reg and the restore reg. No change.
    When I try the Vista Shortcut Overlay Manager, it says:
    "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
    The system cannot find the file specified."
  4. Posts : 72,062
       #43
    Jez,
    Just to confirm, did you log out and in after restoring the default shortcut arrow using Option 3?
  5. Posts : 26
       #44
    Not until you mentioned it. Yes, the shortcuts are back along with the arrows, but any attempt to remove the arrows results in black boxes.
  6. Posts : 72,062
       #45
    Well, at least we found the problem with the icon.
    Did you use the 64-bit version of "Vista Shortcut Overlay Remover"?
  7. Posts : 26
       #46
    Ah, that was it. However, I decided to reinstall Windows 7 and the reg file worked.
  8. Posts : 72,062
       #47
    I'm glad you got it sorted.
  9. Posts : 7
    windows 7 pro, service pack 1, 64 bit
       #48
    Shawn, when I run the bat file i get the message "The system cannot find the path specified" I checked the path(s) above and they are the same except for the user name obviosuly.
  10. Posts : 72,062
       #49
    Hello Peytons,
    That would indicate the file has already been deleted.
    Was that for all files, or just one?
